Gill box scraper
/ Gill box scraper #1
TomLuft
John Deere 790
Recently purchased a Gill box scraper. I am looking for a new blade as this one is worn out. There is no model number on the scraper. The blade is 60 " wide. The hole patern is hole 1 , 2" from end then 13 3/4 " between hole 1 and 2 , then 13 3/4 between hole 2 and 3 , then 13 3/4 between hole 3 and 4 , then 13 3/4 between hole 4 and 5 . Then 2" to the end. The scraper also has a swiveling back blade when operating in reverse gear. The holes take 3/4 " flush mount bolts. Any help in locating a new blade is much appreciated.
/ Gill box scraper #2
Has the blade been reversed (turned over) to utilize the other cutting edge?
Check with FASTENAL for the recessed bolts.
/ Gill box scraper
Thanks, good info
/ Gill box scraper
Thanks. Good info
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2008 Ford F-150 Ext. Cab Pickup Truck (A61568)
2008 Ford F-150...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
New/Unused ATS-T460 Mini Skid Steer (A61166)
New/Unused...
2005 GMC C8500 T/A Altec AM855-E88 86ft Material Handling Bucket Truck (A61568)
2005 GMC C8500 T/A...
