Brush hog accident(s)
   / Brush hog accident(s) #131
Started mowing with bushog in 1976 on the Ford 9n father had on the farm. Was mowing corn stalks one day when I felt my right sneaker slip forward of the foot peg. A minute or two later my foot felt wet. Blood was soaking through the sneaker. A fractured piece of rock had been driven into my foot. Hard to believe that could happen.
The pto on the old 9n was driven off the transmission so when shoving the clutch to stop the momentum from the spinning bushog would push the tractor another 20 feet or so. So stopping required planning ahead. Dangerous really. And I had never heard of an overrun clutch.
Was mowing an abandoned property that a neighbour asked me. At that point I hadn't learned to say no.😜 Heavy tall stuff..couldn't see ahead but he assured me all was flat and clean😂. Felt something bad happening, shoved clutch, and the hog momentum pushed me onto a short half rotten 16 inch firewood pile. And there I was ...tractor turtled on its belly with no traction to get off. I think that is about when I learned to say no.
   / Brush hog accident(s) #132
the local dealer won't take a Ford 9n in trade because of liability issues stemming from that PTO system
   / Brush hog accident(s) #133
just mowed the back of the property, about 3 acres +-.
My hammer fell out of the tool box.
The greedy Bush-Hog gobbled it up and flung it a good 100+- feet across the field.
I've had a hammer there for countless years on numerous tractors.
First time this happened.
Friend of mine was loading his dozer on a trailer that was parked next to mine. As it broke over the ramps a hammer that he used to knock the pins out of his root rake slid back and locked up his steering clutch. Machine spun around and hit my trailer, he was more upset that I was, years later he ended up buying that trailer from me. Still had a crease on the fender from that fateful day.
Was telling an old contractor after something similar happened, well that happened before, he said that's what the farmer said when his horse died !
   / Brush hog accident(s) #134
Yes I get that. Had to ride the clutch to get tractor and bushog going all at once. Couldn't stop quick. Dangerous. I used it for mowing for 40 years but I understood it and grew up on it. When I sold it I stressed the problem to the buyer.
1939 model and still running.
The Kubota is a dream compared to that 9n.
   / Brush hog accident(s) #135
I still have days that I miss my 8N, it was fun, it was nimble and it was a challenge.
I like the modern Bobcat, but there was a lot to be said for the 1950s era tractors!
   / Brush hog accident(s) #136
“Running with the bucket low-ish and tilted up is a better solution than blade straight and level.” Why is that way better? Seems like in either case you could get tossed off the tractor. I’ve stood up now and then but I’ll think twice about it.
If it's angled up then you're more likely to thump the stump with the body of the bucket and it'll ride up and over while still giving you the feeling of impact. If you hit a stump with the blade at the lowest point then you're pretty much guaranteed to fetch up the tractor unless it's a small stump that you wouldn't have to worry much about anyway.
   / Brush hog accident(s) #137
i've had a TS 4 foot brush hog horizontal blade for a number of years. Broke the outer pane of insulated glass on a sliding glass door over eight feet above and 50' behind the mower a couple years ago. Wrapped up yards of drip tape, 1/8' wire cable, electrical cable, old rope, and yep, t-posts hiding in the weeds. Last week I decided to buy a 41' HD flail mower to give a try to. $2020 with free shipping from BetstCo in Oregon. I think the drum style flail may work better on the rougher, steeper, brush infested areas. They claim it will chew through 3" brush trunks. Hey, if it will knock down and eat 2" stuff I'll be happy!
New/Unused Hercules ATV Sprayer (A57453)
New/Unused...
2019 GALYEAN...
2023 Caliber Trailers GH840MST 40ft 6 Ton T/A Gooseneck Flatbed Equipment Trailer (A56858)
2023 Caliber...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Sedan (A59231)
Sedan (A59231)
KSI Conveyor (A56436)
