Brush hog accident(s)
   / Brush hog accident(s) #111
It does happen. Happened to me. Fawn in 5 ft tall grass. Had no idea anything was in grass till that ugly thud from mower. Looked back and deer parts spitting out from rear of mower.
A 5 pound fawn not a 100# adult. They sit tight. Worse when you're using a self-propelled swather with cutters in front and you hit one. The reel then picks them off the cutter and tosses them right up so you can see the carnage. Terrible.
   / Brush hog accident(s) #112
Not a 5 pound fawn. This happened in late September so probably 30-40 lbs. or more. Know people in area that have chopped bigger animals than that
   / Brush hog accident(s) #113
From what I read, they found them by using their FEL set low before they ran over them. Really hard to imagine driving my tractor over the top of a live deer and it still being there to get hit by the mower behind me. And my tractor sits pretty high.
It depends on whether the deer had just shot up an 8 ball of herion laced with fentynal.
   / Brush hog accident(s) #114
   / Brush hog accident(s) #115
I haven’t been on tractorbynet for quite a while, and now I remember why I left……
There are just some people that have to argue, no matter what the topic and whether they’re right or wrong or could possibly be right or possibly be wrong
   / Brush hog accident(s) #118
Oh the things that go through a rotary cutter......Tree stumps are the usual things. This year alone I started the season off cutting tractor high wheat/rye from the past winter food plots and the field had a few groundhog dens in it. Rough to hit one of these and the tool box broke loose from the back of the tractor....a 50 cal ammo box that had been on there for 5 years, and it made a pass through the cutter. Cutter was fine, box destroyed but tools in the box all landed only a few feet away and in two different piles. Had to use the "red wrench"to get the bottom of the can open. Then just today I dodged a bullet while checking a lot I cut on the way to my hunting land. It is a 70 acre plot that is behind a grave yard and they maintain the graveyard themselves but there is a triangle piece of land just past the cemetery that borders on the highway running back to the gate entering my land. As a "good neighbor policy" when I am cutting my land I also cut the triangle too to make the graveyard look symetrical and it only takes me a few minutes. Well today I was removing some flowers that had blown from the cemetery in a storm onto my property and placing them back on the property line. As I was checking this a piece of thin metal fence post, actually 4 pieces, was seen in the grass. Now for the luck part.....there was 100 feet of 1/4 inch metal wire cable strung through it and along the ground. Glad I caught that before it wrapped around the brush hog and I spent the rest of my life removing that mess. I now have 100 feet of wire cable and the posts will be used to stabilize some timbers for a water table with the ends off the trail.
   / Brush hog accident(s) #120
I'd be careful running with the loader down low when bushhogging. I've tried that trick in thick weeds and found a stump that bent me WAY over the steering wheel when standing on an open station tractor to see better. I don't want to hit stumps or whatever but I'd much rather have a repair bill than run myself over with the mower after being thrown from the tractor. Running with the bucket low-ish and tilted up is a better solution than blade straight and level.
As for the original post, it's really easy to hit things you don't see in heavy weeds and next to impossible to scout every square inch by foot beforehand. The use of the term "lawnmower" confuses people, especially since the article showed the nicely manicured lawns of the park but not the tall weeds mentioned in the text of the article. The "lawnmower" was likely a farm tractor. I commonly mow dense weeds 3-4 feet tall and sometimes brush higher than the tractor. My tractors could easily run over someone and I'd never notice the difference between that or a rock, stump, or other commonly ignored obstruction while mowing. Plus, some mowers are wider than the tractor itself. Picture the big batwing mowers used on highways. It's a tragedy but likely only avoidable by the victim herself. I'd expect most people to be awakened well before being run over unless they were under the influence or, possibly, they were sleeping where the first pass was taking place and woke in a daze.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
SUV (A59231)
SUV (A59231)
Sedan (A59231)
Sedan (A59231)
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2020 Diamond C Gooseneck Trailer (A57453)
2020 Diamond C...
