New fifth-wheel hitch setup
/ New fifth-wheel hitch setup #1
S854
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
I've grown tired of of "traditional", heavy FW hitch... 200lbs. or so...
After exhaustive research I've ordered a Curt Crosswing...
It's a 3-piece design with one of the pieces remaining attached to the trailers pin-box... the other two pieces weigh roughly 60 lbs... I can manage 60 lbs...
The instructions Curt supplies involves quite a bit of leveling, measuring, more measuring, subtracting etc... all of which would, IMHO, be necessary for a first-time hitch install...
OTOH, I currently have our old (heavy) hitch, which is set-up correctly for my trailer...
I don't see why I can't simply set both old and new hitches side-by-side on my garage floor, measure the distance from the floor to the top of the old hitch plate, then, make the new hitch the same (close) height...
The new hitch pin connection will be about 5" further back than the old pin placement, with the angle of the truck bed rising as one goes back this would insure at least as much truck bed-to-trailer clearance as the old hitch...
Seems like a no-brainer to me...
Am I missing something?
/ New fifth-wheel hitch setup #2
Dunno,
But just me, I think that thing looks scary as h#ll. Can't even put a finger on "why". Just looks like you can't (or shouldn't) trust it.
I think the base on my B&W turnover ball companion hitch weighs 80 lbs, and the upper portion (it's 2 pieces) weighs 60?
It looks like a battleship compared to that sketchy looking thing there.
I use the forks on my FEL to set mine in and out of the truck bed while all in one piece.
/ New fifth-wheel hitch setup #3
I use my forks for the same chore. Makes it a lot easier
Dunno,
But just me, I think that thing looks scary as h#ll…
When I first saw the aluminum (aluminum!) Anderson hitch I had the same reaction… 40 lbs of aluminum to tame a 16k trailer?!?
NO WAY!!!
Then I thought back to the beginning of my motorcycling days… the then revolutionary, Bell full-face helmet made a big splash with its full-face design… being made entirely of fiberglass it was also heavy and rather cumbersome…
Fast-forward 50 some odd years… all helmet manufacturers now offer the full-face design… made with modern materials and created with modern day technology… the new helmets are light-years ahead of the original Bell design with regards to safety and protection... All the while being literally a fraction of the weight…
Curt is a well-known hitch manufacturer… and the roll-out of their new Crosswing offering is several years behind the first (as far as I know) non-traditional FW hitch sold by Anderson…
I’m a proud Luddite in regards to most purchases, however, there are some newfangled items I’m willing to give a chance…
It‘s coincidental this guy just ditched his Companion for the Crosswing… is he right? Absolutely not… but for his situation it was, according to him, the right move…
/ New fifth-wheel hitch setup #5
Why would Curt require the pin position to move 5 inches back? Talking about the trailers Pin position correct?
As much as it is a pain to R and R the Reese Fiver - I do trust it Well other than the time I wasn't paying attention and put the forward mounting pins in the wrong holes...
I bought the Curt Fifth wheel to Gooseneck adapter plate and installed a couple of their hitches on Jeep Grand Cherokees . No complaints with any of it but as stated earlier looking at the crosswing, it just looks lighter duty than a full size fifth wheel mount the plate diameter appears smaller?
Looks like you have to attach it like you would a gooseneck by dropping the 5th wheel pin in the hole instead of backing up into the jaws?
It does seem rated a bit lower than some others that are 10k higher at 30 K lb. Then again most of us myself included, will never pull a 30k trailer
I think I borrow Slowpoke Slim's method and start using the tractor FEL to R and R mine. They Really are heavy.
I also used my forks to remove/install my old hitch… at home..
I just can’t figure a way to tow both my FW and my tractor from state-to-state so I can have an open truck bed while camping…
Sometimes there are other considerations….
/ New fifth-wheel hitch setup #8
OP,
I hope you get many years of good service out of your new hitch.
You did mention Anderson...
There have been huge firestorms of debate over those hitches on some of the RV forums, and I don't want to start one here, OR derail your thread...
But way too many of those Anderson hitches have folded up in use for my comfort. Much, much debate on what causes it. I don't care if it's little green aliens, climate change, or communism. It's too much "smoke" not to have some "fire", aka, too many to write off to some obscure cause or error. I don't care if they (Anderson's) do come with a "lifetime warranty" (I believe they do?), I'm not interested in one for no other reason than I've seen photo evidence of way too many wrecked ones on various forums. Don't really care what the "cause" was either.
But I hope your Curt is great for you.
It's the design of the Crosswing... in relation to the old hitch, the new one places the "jaws" (there are no jaws on the Crosswing) 5" aft... which moves the pin 5" further away from the truck cab... not a big deal in my situation as I'm towing with a long-bed...
The tow rating on the Crosswing is 20k... I'm not gonna come close to 20k so I'll consider it "overbuilt" for my purposes...
/ New fifth-wheel hitch setup #10
I don't know if your rig (truck and 5th wheel) weight leaves you enough capacity, but what about towing a flatbed trailer behind your 5th wheel with your tractor chained down to it?
/ New fifth-wheel hitch setup #11
I have an Anderson on my 2015 GMC 2500 HD and pull a 30' RV. A friend also has an Anderson on his 2015 GMC 2500 HD and pulls a 42' RV. Neither of us have had any problems. Ours are the model that connects to the gooseneck hitch in the bed. Which model is it that people are having problems with? The ones that mount on rails in the bed or the ones that mount to the gooseneck? The only problem could be caused by failure to properly torgue the bolts on the bed hitch and trailer socket for the gooseneck version. Improper installation of the rails or their locking devices would seem to be the only issues with the other versions.
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
Case HI Combine w/ 2010 Headflex (A62613)
Case HI Combine w/...
(2) 13.50x60 Tires and Rims (A65640)
(2) 13.50x60 Tires...
(1) 59 1/2" Wx94 1/2" Lx3/4" Thick Metal (A64127)
(1) 59 1/2" Wx94...
2016 Chevrolet Silverado 3500 Flatbed Truck, VIN # 1GB4KYC8XGF238980 (A65563)
2016 Chevrolet...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
