93 octane fuel in a low compression engine
/ 93 octane fuel in a low compression engine #1
1Mech
Gold Member
Sand Springs, OK & Yellville, AR
International B414
I recently bought an old International B-414 gasoline tractor, reading through the owners manual, I noticed it called for 93 octane fuel.
Now this is only a 6.3:1 compression ratio engine, why in the world would they recommend such a high octane fuel?
Was octane rated differently in 1963?
/ 93 octane fuel in a low compression engine #2
I think they changed the way they rated octane in the 1970s with the advent of catalytic converters and unleaded gas. My best guess is that modern regular octane gas will be more than sufficient in your tractor.
/ 93 octane fuel in a low compression engine #3
Octane ratings were changed some long time ago, now being "research octane number" (RON) + "motor octane number" (MON) / 2. That said, I cannot imagine any reason that a 6.3:1 engine needs anything greater than the least octane rating gasoline you could possibly find. I have done octane testing on airplane engines from 7:1 to 9:1 compression. 7:1 runs happily on 80 octane, which is no longer available as an aviation gasoline, the 9:1 runs happily on 91 octane.
It is possible, though I think unlikely, the the tractor engine manufacturer wanted some tetra ethyl lead (TEL) = "leaded gasoline" through the engine, knowing that higher octane gasoline used to have lead. You're out of luck with that in any [auto gasoline] case. The lead lubricates the valves a little, but not enough that I'd worry about missing it. If you want to be ultra conservative and run some lead, go to your local small airplane airport, and buy 5 gallons of 100LL aviation gasoline - it still has a fair amount of lead, and is 100 octane. Mix a little in with your regular unleaded autogas. When I used to run auto gasoline in my airplane (which was approved), I would try to get one tank every 20 tanks of 100LL just to get a little lead into the gas for the valves.
Your greater risk will be the effects of ethanol, which is probably mixed into the gasoline you're buying. It has a lesser energy density that pure gasoline, and ethanol may attack some of the non metallic components in the fuel system. Again, low risk, but not none...
If in doubt, run the auto gasoline you can get, and keep the RPM up, and the load down on the engine - rather than lugging it at low RPM. If detonation is a risk (which I very much doubt anyway) it's less a risk at higher RPM, low load, than the other way around....
/ 93 octane fuel in a low compression engine #4
Check the stations in your area - internet is the easy way. Use a search term like no alcohol gasoline near me. If you don't use the tractor a lot that could be a good way to go. Alcohol retains water and can corrode metal parts it contacts (fuel line, carburetor, etc.) but it can also destroy older rubber or neoprene lines. Neoprene has been reformulated to deal with that. Many of the newer cars have plastic fuel tanks and fuel lines.
/ 93 octane fuel in a low compression engine #5
I have an International 354 which is a similar tractor to yours although a few years younger in which I've been using regular gasoline since it was new. I suspect the motor in mine is pretty much the same as yours and I've never encountered any problems which I can attribute to low octane gas. Out of curiosity I've just checked my Owner's Manual and can find no reference or suggestion whatsoever as to recommended octane level so it can't be very critical!
/ 93 octane fuel in a low compression engine #6
agree with the above consensus. you have a great old school machine, & i'd go the extra effort of locating non ethanol fuel just as i do for my small engines & old school truck. w/stabilizer additive, you engine will last forever. around here, non ethanol usually is premium 91, looking at your original question. i see no prob w/higher octane, along w/benefits of non ethanol.
/ 93 octane fuel in a low compression engine #7
You definitely do NOT want to use gas with Ethanol in it. It will destroy your carb O-rings and gaskets. Locate and buy the 91 octane fuel and ad some of the additives that are designed for older engines that originally used leaded fuel.
Your pockit book will thank you.
Richard
Thanks for all the replies, I am bringing it home from Missouri on Monday. The previous owner said it had a VW carburetor on it, he was using a "choke cable" on it, direct throttle control, so I need to get the proper carb and the governor linkage, which is currently not connected. Also need to loosen up the non power steering a bit, check for oil in the steering box.
/ 93 octane fuel in a low compression engine #9
Not sure but think you can purchase a lead additive from Wally world
willy
/ 93 octane fuel in a low compression engine #10
My educated guess is IH simply wanted it run on regular road gasoline.
The octane rating on the pump was different in the '60s, it was the research octane number like most of the rest of the world continues to use on their gas pumps. The octane number you see on the pump in the U.S. today is the average of the research octane number and the motor octane number. The current octane number is usually called "pump octane" but is formally called the "antiknock index". The research octane number is usually about 10 or so points higher than the motor octane number for automotive gasoline, which would put 93 RON gas at about 88 pump octane.
Your International B-414 was tested by Nebraska in 1962 and they used a regular leaded gasoline with a research octane rating of 92.2 and a motor octane of 84.6, for a pump octane of 88.4. Leaded regular was usually 88-89 pump octane between the early 1960s and when the EPA banned it at the end of 1995. The octane of regular unleaded gasoline today is very close to the octane of regular gasoline available in the '60s. The current mid-grade 89 is at least as high as the regular back then and modern 93 octane premium is not terribly far from what most leaded premium available back then ran, which was usually about 94-96 pump octane.
The main issue with running modern unleaded gasoline in an older engine that originally was designed to run on leaded gasoline is exhaust valve seat recission if the valve seat wasn't hardened and the engine is run hard for a lot of hours. I don't know if IH did hardened valve seats in 1962 or not. Almost everything made after 1970 or later did but as there was "white gas" . I would not worry about the small amount of ethanol in modern regular unleaded, just use the tractor with some regularity to not let the fuel go stale, which is excellent advice no matter what fuel your tractor runs on.
/ 93 octane fuel in a low compression engine #11
Richard
I run ethanol in my 76 model truck for 7 years straight. 55 miles to work, one way. After 7 years I finally had to put a wrench on it, I blew a tire. I went ahead and took carb down because of all that so bad ethanol. I just put it back together, everything was fine. Did not put a kit in it, just put it back on the engine and kept going.
/ 93 octane fuel in a low compression engine #12
Richard
What O-rings do you think there might be in a gravity fed tractor?
/ 93 octane fuel in a low compression engine #13
Richard
There isn't that much alcohol in regular unleaded, it is no more than 10%. The issues with materials incompatibility show up at higher concentrations, usually 25% or more. Basically when you get to the point where you have to change jetting is when you may start to have issues. We're dealing with at most 10% alcohol here, not E85 or methanol racing fuel.
I looked at the MSDS sheets of a few lead substitute products. They are mostly just aromatic and aliphatic hydrocarbons designed to offer a small octane boost, although some like STP put other organometallics like ferrocene in there for the same reason. Ferrocene can cause iron-containing deposits inside of the engine. I would skip that stuff.
/ 93 octane fuel in a low compression engine #14
I've been running reg. station pump gas in my 1950 Fordson for the past 35 years. Not an issue. I do need to exercise the fuel jet needle after a long layover however. 1/4 twist out, then 1/4 twist in. (It's a thumb screw)
Best power in winter is with the screw out an additional 1/4 turn anyway.
/ 93 octane fuel in a low compression engine #15
If it was my tractor I would be using regular gas 87 octane
without the corn juice and check wally world for an additive
with lead supplement to help save the valves
willy
/ 93 octane fuel in a low compression engine #16
Well lets see, O-ring on the main fuel jet adjustment, the O-ring on the low speed fuel jet adjustment, the possible rubber like seat for the float needle, and the float bowl to carb housing seal.
Richard
/ 93 octane fuel in a low compression engine #17
willy
87 octane without ethanol may or may not be available where the OP lives. Here in Missouri it is not legal to sell anything other than 91+ octane premium gasoline without any ethanol in it- all 87 and 89 octane gasoline must have some ethanol in it. The best information I can find is that LA, MI, MT, OR, PA, and WA also have similar rules. Buying 91 octane without ethanol here costs about 40% more per gallon than regular unleaded and there usually are only one or two stations in an entire county that carry it- very similar to buying off-road diesel at a pump.
/ 93 octane fuel in a low compression engine #18
WELL you can tell the gov stepped in!!!!!!!!!!!
they screw up everything they touch or come in contact with
willy
2005 (INOPERABLE) FREIGHTLINER COLUMBIA 120 (A67714)
2005 (INOPERABLE)...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2008 THE MACHINE CO. THAWZALL H250 HEATER (INOPERABLE) (A68842)
2008 THE MACHINE...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2013 Jeep Wrangler 4X4 SUV (A66738)
2013 Jeep Wrangler...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
