Exposed Aggregate concrete help
/ Exposed Aggregate concrete help #41
Lots of helpful information in this thread, unfortunately after the fact. sucks that the job didn't come out well. Going forward if you decide to tear it out and start over, decide on what color of exposed aggregate you want. how it will look with your house and landscape. As mentioned there different colors and size of stones. do you want grey, black, black and white. seeded or stones in the mix. It takes time to vet a contractor and go over the details of the projects to be sure you will end up with what you expect. There is nothing worse than having to look at something day after day that your unhappy with.
/ Exposed Aggregate concrete help #42
How much PSI would work?
As high as you can. Typical pressure washers are between 2,500 and 4,000 depending on your needs. I have an aggregate patio and notice each year that I pressure wash a little more of the concrete washes away. Now it’s old enough that some of the pea gravel also comes up so I’d spot test and try not to use the high pressure constantly on one spot.
/ Exposed Aggregate concrete help #43
And the brake lines crooked for drainage as well? :), not it was supposed to be level because i'll put a row of decorative bricks-retaining wall on the edge.
I'm already $4K ++, now mini x, a dump track, pay to the dump side, then another God know who contractor, about $10K in a 530Sqft patio. I'd say a little expensive :unsure:
I'll check this option.
But very educational!
/ Exposed Aggregate concrete help #44
I poured concrete for nearly 20 years and was a journeyman cement mason in the 1970's and 80's. During that period, I poured and finished hundreds of swimming pool decks and patios. Most of the pool decks were either seeded exposed aggregate or Kool Deck.
My opinion is the workmanship is poor compared to most of the wash-exposed aggregate I have seen over the years.
Is there any way to make this job look like what you want? Other than removing and replacing it with a competently poured and finished patio, the answer is no. All the blasting and grinding in the world will not produce the finish you are looking for.
If you go with the "remove and replace" solution. I suggest having the contractor provide you with photos of his/her work and come to an agreement on the finish you want prior to signing the contract.
The photo is of my pool deck. It is seeded exposed aggregate and was done by a local pool contractor. He is one of the best in the area.
/ Exposed Aggregate concrete help #45
As a retired contractor that did my first exposed agregate job with my large tow behind mixer. It was around my own pool in 1973. I used a rock known around the area as Yuba quartz. Likely it came from the Yuba river. I found that trying to use the rock that came in mixes were too variable and just didn’t look like seeded job. If your contractor won’t take care of it then methods described above are in order. Send him a certified letter and if he doesn’t respond then you gave him the chance and move on with a remediation plan of having a place who specializes in repair or overlay whichever is best suited. The low spots are concerning. Then you can get what you want and go after him for the cost.
/ Exposed Aggregate concrete help #46
Tried it as well, the wire wheel leaves black/gray/silver metal color on the rocks, looks ugly.
Here is what i was expecting:
Well, did you have a written contract? Did the contract contain one or more images of what you expected? Did this fellow have references? Did you visit any of his references for exposed aggregate jobs? Have you paid him? (If so, why!)
I've had fellows promise this and deliver that - but they do not get paid for labor or materials if the work is not done as promised and described in the contract we sign before a spade is put to earth.
Last guy agreed to do a drive with X tons of large rock and Y tons of ABC crusher run for Z dollars. After he left the gravel delivery driver called me to say he hadn't been paid for a load (or two). I advised him that I'd paid the contractor in ful and had the canceled check (image) to prove he'd cashed them. I also showed him a copy of the contract.
He said "I never would have signed such a contract."
I replied "Well, then, you would not have gotten the job."
Unfortunately, if there ever was a time when a man's word was his bond, it's long been over and your best protection is a written agreement and payment upon completion per the the agreed terms.
Also a good idea to read up on the work you're wanting to contract out so you might more readily spot the phonies who think the bedrock goes on the drive last - or what you got is "exposed aggregate" because "You can see aggregate!"
Remember, there's a sucker born every minute.
/ Exposed Aggregate concrete help #47
You are being a little hard on the man aren't you?;) Contracts and written papers are one thing but the end results are all that really matters. On small projects like this, all the paper in the world is not going to fix something like this unless the guy that did the job is willing to admit his mistake and fixes the problem on his own.
The problem with concrete is there are too many variables that can take place on a small job like this. Weather, site conditions, problems at the batch plant, hangovers, and there are those that are out just to make a quick buck.
Most all of the really good concrete contractors out there won't even look at a small job like this, they want 100-yard or more pours before they will even talk to you.
There are some good small job contractors out there, but they are hard to get because they are so busy and book months out. People are pretty much the same all around and when they decide on doing some project, they want it done now and that is when they turn into fish and believe me there are a lot of shardy fishermen out there.
Pretty much all the small job concrete finishers I know want you to pay for the concrete up front, (they have been burned a time or two also). All they are doing is supplying the labor to finish the product you have bought. Most all of the finishers, at least in my area charge for labor the same as what the concrete cost and if you have site work, they charge extra for that. If you do your own base and form work that adds a few more worms in the can to wiggle out of in case something goes wrong, and someone tries to take him to court.
All this really means is that no matter what you do there will be no guarantee of the end results. It should be but in today's world you never can tell anymore.
/ Exposed Aggregate concrete help #48
You probably should have asked this on a concrete contractor website. Three pages of guys weighing in on something they know nothing about. Grind it, seriously? Pressure wash, let it wear away, just guessing. Many homes have exactly you want; I guess some guys haven't seen it. The contractor was informed and didn't know what he was doing. Nothing else will fix it. Omega Woods gave you the only true answer - you have to take him to court, sadly, if he won't redo this.
Most concrete contractors I have worked with on construction projects have had to remove a concrete pour and do it all over again at some time. If it didn't come out to what was written in the contract it becomes an expensive "do over" for them!
/ Exposed Aggregate concrete help #49
That job is ******** . That should been rinsed clean . Hope you ?did not pay yet .
/ Exposed Aggregate concrete help #50
I think I'd bring out some patio chairs and enjoy it. Worry about something that matters.
Understood that the result doesn't look like what you wanted it to look. I've noticed the same sort of problems with photos of myself taken in the last few years.... they just don't look like I'd expected.
But on the other hand that concrete looks strong and even looks like it might have some decent drainage. Frankly I've seen far worse concrete jobs. A few months of foot traffic will wear the exposed cement faster than the stones and then you will have closer to what you expected. I'd say give it some time.
rScotty
/ Exposed Aggregate concrete help #51
rScotty
That is a complete bullcrap post. That kind of attitude just blows my mind. It DOES matter to the OP. Maybe you like to have your stuff look like crap, but a lot of people don't. The guy paid for a job and did not get what he paid for.
/ Exposed Aggregate concrete help #52
@2515R Dude . If you read @teesquare's post and @Yanmar VIO's posts, they are spot on. Ignore the rest of the idiotic posts from guys that have no idea what they are talking about nor have the same level of expectations that you do. The second house that I built had a large exposed aggregate front porch area which included steps down to an even larger sitting area. The exposed aggregate looked great and was great to walk on (not slippery when wet). My contractor did not "seed" the concrete after it was poured, but rather, it was poured with the correct mixture. Unfortunately, your contractor did an absolute crap job not only from the aggregate perspective but just being able to pour a flat piece of concrete.
If you have pictures that you texted him of what your job was to look like and any other trail of communication, I would take him to small claims court at the very least. If it were me, I would be going after him like a hound after a rabbit.
/ Exposed Aggregate concrete help #53
New guy coming on harsh as a "know it all". Good luck.
two final notes.
1. He gave me all wrong info, his name, his adres, his company name, the do not exists, so no way to find him, besides now i have more important thing to take care of. God will close account with him, such people never get rich not happy. He is going to run all his life.
2. I'm going to wash it two times with acid, then pressure washer, then acid stain light tan color, then seal it with wet look. I tried it on a small area, it worked. Not 100% but reasonable.
That is it, thanks for all advice and good words.
/ Exposed Aggregate concrete help #56
I hope and pray it comes out to your liking 2515R Dude, Take the high road your better for it and you're right the good lord will take care of them.
I hate hearing stories like this from scrupulous contractors with no sense of pride in their work. unfortunately, they are out there but so are the good ones.
-God bless
/ Exposed Aggregate concrete help #57
I did quality control work for a prestressed concrete company and we did a sewer treatment plant in Pensacola that is almost all exposed aggregate panels. Most of the solutions listed in these 6 pages won't work, at least not to make it look correct.
Good luck with your experiments, and go kiss your bride and tell her it will be all right!
David from jax
/ Exposed Aggregate concrete help #58
David from jax
The capability of a precast plant far exceeds what homeowner can do. That is why the potential solutions are different
/ Exposed Aggregate concrete help #59
Looking for an advise and TBN collective wisdom.
I hired a concrete contractor to make me a patio with exposed aggregate concrete.
The guy came, poured the concrete, sprayed the retarder, waited about 2 hours, washed and left.
When he was leaving i asked them why there are so many spots covered with the concrete, like 70-80%.
His answer was, it is send and concrete dust which tomorrow you can wash with regular hose. It is not going to harden.
Next morning i could not wash it not with regular hose, nor with jet spray.
I contacted him, he told me he would come later this day. Needless to say he never came, does not answer the phone, texts and such.
The question is: How do i remove a thin layer of the concrete to expose the aggregate?
I tried muriatic acid and KLEEN KREETE - no dice.
Are there any other options?
View attachment 810840View attachment 810841
You need a terrazzo grinder. They should be available at a rental store. I have done small areas with a cup grinder an area that large needs the terrazzo grinder..
/ Exposed Aggregate concrete help #60
I am retired - but owned a company that fixed concrete problems. I currently consult with architects and owners in commercial construction projects.
First - Don't panic and do something to ruin what you have. It can be made to look much more like what you desire. And - Yes, you CAN make it worse. Especially by following many of the in-experienced ( and some hare-brained ) advisements I see in this thread.
Second - contact a company called ProSoCo. They are on line. They are the biggest and best at finding ways to fix and maintain exposed aggregate as well as many other forms of decorative concrete. They will have a rep that work with commercial construction material supplies that serve your area. Find out the names of the companies that sell their products.
Third - Once you know more about how the ProSoCo cleaners, acid based detergents, and sealers work - decide if it is something you want to perform or have a contractor that specializes in this type of "cleaning up behind a slob" work do this. After cleaning - this surface will need a penetrative water repellent applied to prevent freeze/thaw spalling ( rocks popping out )
And - lastly...folks who have no actual experience in these things seem to feel empowered to get on a computer and tell someone else how to fix" a problem. They ought to be head slapped for that. And, you really should do your research for fixing this with an attorney letter to the concrete contractor - and Google. Not a discussion forum about tractors.
I will private message you my phone number and if I can be of further help - please give me a call. I feel your pain, and in honor of your wife and her diagnosis - and will do my best to answer any questions and direct you to people/places for getting this solved.
T
I've poured slabs the way he wanted in his picture. You cannot let your screed board rest in one place at any time. It will leave a dip in the rocks when it is washed off. I also had a few bags of washed rocks handy and hand broadcast them over entire project while concrete was wet, just after screeding off. Then I turned screed board flat ways and patted rocks down flush with top of slab. Trick was I had an extendable paint roller handle with a soft push broom on it. Spray with a hose nozzle with a shower setting, sweep lightly as I spray, turned out nice.
2019 CHEVROLET EXPRESS 3500 PASSENGER VAN (A59912)
2019 CHEVROLET...
2016 Cadillac XTS Sedan (A61574)
2016 Cadillac XTS...
JLG Aerial Lift Service and Maintenance Manuals (A63117)
JLG Aerial Lift...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
2019 FREIGHTLINER M2 106 4X2 S/A 26FT  BOX TRUCK (A59912)
2019 FREIGHTLINER...
