Exposed Aggregate concrete help
/ Exposed Aggregate concrete help #1
2515R Dude
KY
Branson 2515R
Looking for an advise and TBN collective wisdom.
I hired a concrete contractor to make me a patio with exposed aggregate concrete.
The guy came, poured the concrete, sprayed the retarder, waited about 2 hours, washed and left.
When he was leaving i asked them why there are so many spots covered with the concrete, like 70-80%.
His answer was, it is send and concrete dust which tomorrow you can wash with regular hose. It is not going to harden.
Next morning i could not wash it not with regular hose, nor with jet spray.
I contacted him, he told me he would come later this day. Needless to say he never came, does not answer the phone, texts and such.
The question is: How do i remove a thin layer of the concrete to expose the aggregate?
I tried muriatic acid and KLEEN KREETE - no dice.
Are there any other options?
/ Exposed Aggregate concrete help #4
I would try pressure washing the surface. Professional repair would be sandblast
/ Exposed Aggregate concrete help #6
Just use a wire wheel on a grinder to hit what looks like low spots. Then rinse and repeat as needed. What did you think it was going to look like? :rolleyes:
/ Exposed Aggregate concrete help #7
I’ve used a sponge and rags as the patio dried followed by water and brush/broom…
In time the residue quickly wears off from the polished river aggregate I use.
  • Good Post
Reactions: JJT
/ Exposed Aggregate concrete help #8
That was my first thought, and one the contractor should have asked.
/ Exposed Aggregate concrete help #9
I've made a concrete hearth, ground it down, looks like granite, almost...
I would try as high of psi as I could get. If too abrasive you can get wider spray pattern
I tried 1600, nothing. I can rent up to 4400 PSI, it is $100 a day and 1 hour driving, not an issue if it works., but if not, it is another $100 in additional to all the money this jerk stole from me and acid and other things.
Grinding will give a different appearance than the exposed aggregate
What tool do I need to grind it? BTW, is it going to be shiny or rough? Do you have any pictures?
Tried it as well, the wire wheel leaves black/gray/silver metal color on the rocks, looks ugly.
Here is what i was expecting:
Not this:
/ Exposed Aggregate concrete help #18
/ Exposed Aggregate concrete help #19
How much PSI would work?
minimum 4,000psi and high volume
do nothing and it will wear naturally over time. if you live in a cold climate salt your walkways if you want the old worn out concrete look faster.
/ Exposed Aggregate concrete help #20
That is two very different methods and I believe your contractor should have known the difference. It's to late now, what you have will never look like what you want.
Yep. That's two different methods. Did you show your contractor that picture before he started or bid the price? One is the cheap route the other is a loaded aggregate. Typically done by hand and more expensive. You probably got what you paid for. But I wasn't there. :cool:
2004 Freightliner FL70 Water Truck (A68183)
2004 Freightliner...
Cadman Powerpak PT Power Unit (A64912)
Cadman Powerpak PT...
2012 FREIGHTLINER CASCADIA 125 6X4 TANDEM  SLEEPER TRUCK TRACTOR (A69167)
2012 FREIGHTLINER...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer w/ 7 Ton Gooseneck Trailer (A66734)
2023 JCB 3TS8T...
213135 (A64276)
213135 (A64276)
2007 CHEVROLET MALIBU CAR (A66091)
2007 CHEVROLET...
