rv7charlie
- Joined
- Jun 21, 2020
- Messages
- 97
- Tractor
- Kubota M4700
I suppose this might be considered a rant in the form of a question, but here goes:
Any thoughts from you 'pro' users on why the M4700 has such a big speed jump from high 2nd to 3rd? Mine gets about 95% of its hours running a 7' cut finish mower. (Mowing ~3 acres of my land, and 20+ acres of a grass airstrip six to eight times a year whenever my turn rolls around.) 2nd gear & 2600 rpm gives a pretty cut, but takes a generation to mow 20 acres. 3rd gear & 2600 rpm gets it done in about 2.5 hours, but gives a ragged cut and the mower tends to deflect the grass at its edges instead of cutting it. (This is with freshly sharpened blades.) Going any slower in 3rd results in the mower turning too slow, making the cut look even worse. When you look at the speed range chart, the speed jumps from about 8 mph to around 12 mph when going from 2nd to 3rd.
Anyone have any idea on why Kubota would have built such a wide gap into their system? I realize that most jobs don't get done in 3rd or 4th, but mowing really does need either a slightly slower 3rd, or a 'variable ratio' PTO rpm. Shelling out the money to replace the tractor with a hydrostatic drive model just isn't in the budget.
