Dftodd
Super Star Member
- Joined
- Oct 19, 2014
- Messages
- 10,551
- Location
- vilonia, arkansas
- Tractor
- Massey Ferguson 1825E, Kubota Z121S
But..... your pressure when using a grease gun should relieve out through the outer bearing.It also pushes through the inner bearing at the same time. They both have spaces between the rollers.
The little hole for the grease to enter the axle cavity is between the lip seal and inner bearing.
If a grease gun is pushing out the lip seal, then there is a clog somewhere between the inner and outter bearing.
Any decent mechanic should recognize that fact and address the issue instead of blaming it on the tool
