Seat height on MT series UPDATED...input requested
/ Seat height on MT series UPDATED...input requested #1
flyinghigh
century
Does anyone know if there is a seat height adjustment in the service manual for a MT347, MT357 tractor? We looked at 4 different ones this morning and the height ranged from 15-18 inches (measured it with a tape measure with it empty)...that is huge if you are tall like I am.
There are no user controls on the seat to change height, just a tension adjustment to vary the "spring" in the seat when you hit a bump.
I am thinking if you get inside the seat your might be able to loosen some bolts and adjust the up/down or worse case put some spacers in.
Anyone have any thoughts or experience with this?
so according to this parts manual, item #6 is a knob height adjustment...anyone have this on their seat?
/ Seat height on MT series UPDATED...input requested #4
I did a simple seat height modification.... added two
1-1/4" square tubes under the mount (4 bolts). There are not any 'real' height adjustments on the stock seats, only minor adjustments.
Well that is discouraging to hear. I wonder why they are all different heights at the dealer.
/ Seat height on MT series UPDATED...input requested #6
There IS some adjustment, just not "inches".... maybe
1 1/2"
how do you change the height? is there a knob?
/ Seat height on MT series UPDATED...input requested #8
Yes, there should be a knob to adjust. Maybe the "newer" models no longer have the option?
It appears either they removed the knob or changed the seat...or just had a shortage so did a production run without them.
Looked at a TYM yesterday...it has the same knob that LS shows on their parts diagram actually ON THE SEAT :)
Drove 2 hours tonight to confirm there is NO seat height knob on any of the LS tractors at our dealer
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
Refurbished KBH Tender (A63689)
Refurbished KBH...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2004 GMC 5500, Duramax Diesel Truck Vin# 1GDE5E1234F520387 (A62679)
2004 GMC 5500...
E-Ton Viper RXL-50 FOURWHEELER (A62613)
E-Ton Viper RXL-50...
