TX1300F tractor split: any tips or tricks?
/ TX1300F tractor split: any tips or tricks? #1
marcelPL
Gold Member
Poland
iseki TX1500 and TX1300F
I will soon have to split my TX1300F to replace the clutch.
This is far from my 'normal' world. Is there anybody here who has already done this excercise and has some tips or tricks available?
many thanks
Marcel.
/ TX1300F tractor split: any tips or tricks? #2
I took a similar design & vintage tractor engine out for some repairs over 16 years ago - here's few photos showing some of what's involved.
These will help: Metric hand-tools, wood blocks & wedges and engine hoist would be handy to have, but I am sure can be done without it also - it just makes the job lot easier.
Please note the clutch is pretty big for small tractor (19 hp) due to combination clutch for gears & PTO
This was around year 2006 or so:
Tractor 006 - Copy.jpgTractor 013 - Copy.jpgTractor 014 - Copy.jpgTractor 021.jpg
Almost all back together, except the front end loader!
Pretty impressive. Good work, mate! I wish you were my neighbor .
The Iseki (I think) works a bit different. Splitting means the front and rear cannot stay together (like in your photos) . With front wheels still connected. But maybe I am wrong.
I got the parts in today (from Hungary, it took almost 200 euro), so the moment of 'just do this' has come closer... :(
But thanks for the photos, it already shows quite a lot of what is waiting for me. Being a software engineer, I have no clue about a lot of these things....
Marcel.
/ TX1300F tractor split: any tips or tricks? #4
Marcel.
Marcel,
Thanks, glad if I could help - yeah I see it's a bit on distance in-between us!
Actually during the Ford 1310 disassembly only things sort of 'holding the front axle in place' were the steering link and the front drive shaft, as can be seen below in the zoomed-in section of my previous photo.
IE. The engine acts also as a frame towards the rear, but there is a separate heavy flat-bar type frame from the engine forwards front axle.
The flat-bar frame can partially be seen in one of my photos.
These 1980's design tractors are pretty simple to work on since the cast iron engine/transmission/differential are also the main frame of tractor.
Cheers,
/ TX1300F tractor split: any tips or tricks? #5
I hope you find it easy to do, I found the 4 wheel drive shaft was up there as about one of the most fiddly (awkward) parts to remove, once you remove all the bits that are attached to the rear, oil pipes, cables, hoses, the engine will lift out of the frame its bolted too, it will be tight, and the bolts are fine thread, a few of mine threatened to pick up but I managed to remove them, I think from memory they are different lengths so be careful when rebuilding,
I'll attach some photos for yo to have a look at what you can expect to see.
DSC02549 by chrismac2012, on Flickr
DSC02548 by chrismac2012, on Flickr
DSC02550 by chrismac2012, on Flickr
I may stand corrected and you can leave the engine fitted to the front axle, rolling it forward.
Untitled by chrismac2012, on Flickr
inside the bell housing,
Most off good luck,
Chris
/ TX1300F tractor split: any tips or tricks? #6
I've always split the tractor to replace a clutch. There is a lot less to remove than pulling the motor. Put blocks between the engine frame & front axle so it doesn't tip. Block the front & use a floor jack to move the back half,
/ TX1300F tractor split: any tips or tricks? #7
Most importantly is to create a centre-tool before you take the old clutch off and which will garantee you can rebolt the new clutch exactly centrered. If this centering of the new clutch is done nicely, at least with attention to detail, the reassembly will go easily. If not, you might discover the carter doesn't properly match the threads. Temptation to hit the bloody carter with some violence to get bolts in, can be the beginning of another problem... Use a torque spanner (check force tables before you start to see if your spanner meets the requiered range) and lock-tight liquid to not have a spontaneous split in the future :)
/ TX1300F tractor split: any tips or tricks? #8
If you don't have a clutch alignment tool, center the dick in the pressure plate. I've done this many times.
/ TX1300F tractor split: any tips or tricks? #9
I always get myself a couple of bolts that fit rear of engine. Let's say 4" long. Cut the heads off. Hacksaw straight down in the bolt to make it so where you can use a flat head screwdriver to remove it. Put those two bolt shanks into Engine for line up pins. I know it has short dowel pins but your input will hit pilot bushing before your trans hits the back of engine. Plus you can kinda measuralize things to see how skrate you are. Be sure you put them two bolts in a place you can remove them from. Ive taken them apart and pilot bearing was gone, not there anymore, so check yours. Be sure to check that.
/ TX1300F tractor split: any tips or tricks? #10
So the big question remains : have you started cutting her in two already ???? :)
So I started the split, but I am kinda stuck here on the drive shaft towards the front wheels.
Does anybody know how to get this black protection cover off? I took out the bolt, but it's completely stuck.
Also the part in the middle does not seem to be ok.
On gearbox side I see a cable or wire running through the connection. Should I just remove this wire and hope the drive shaft will drop when I split it? (And worry about getting it back together later I guess)
Thx for help guys...
Marcel.
View attachment 806838View attachment 806839View attachment 806841View attachment 806840View attachment 806842View attachment 806843
Strange. There should be 6 or 7 photos there, but I can see only 1.
Here is the black cover:
And here is the middle part:
/ TX1300F tractor split: any tips or tricks? #14
Hi Marcel, I think I mentioned earlier this would be one of the worst jobs of your clutch change, the cover is just tight, rubber seal, yes cut the wire and knock the pin out, I am trying to remember if I cut boths ends and slid the other end on a bit but cant remember, but by time I am thinking this I possibly did.
Good luck
Chris
/ TX1300F tractor split: any tips or tricks? #15
We're the wire goes through the front drive shaft is a roll pin that needs to be driven out! Ask me how I know! Had to replace input shaft and coupler on a tx1500.
Well by now things are not going well.
I have taken everything from tractor to perform the split, but i cannot disconnect the front drive shaft.
At gearbox side I could see and reach this spring pin, but whatever violence I used, it refused to be driven out.
On the front side there is this cover. Somewhere I read this is plastic, but hammering it with steel for sure doesn't sound like plastic. Almost certainly it's metal. And it won't move in any direction, no matter what I try.
Worst of all is that I have this FEL installed, which gives me hardly any room to work. Also this FEL will block the drive shaft when splitting the tractor for more than a few centimeters.
Having to remove the FEL will make the task of splitting the tractor one of epic proportions.
Anybody has any suggestions left?
/ TX1300F tractor split: any tips or tricks? #17
With my Kubota B7000, almost the same as your Iseki, I always took the loader off. Just so much easier to work on the tractor.
Anyway, try pull the cover and slide it back and see if you can disconnect the front U joint there instead.
Pull it where? I took out the bolt underneath, but the thing refuses to move in any direction.
Also I checked the manual, and cannot see any other thing that might be blocking it...
Thx,
M.
/ TX1300F tractor split: any tips or tricks? #19
Thx,
M.
There are 3 bolts on that cover. 1 on the bottom and 2 on the top. Once those are out, you should be able to slide the cover back a little bit.
Well I am right now looking at the manual, but there is nothing there. Just one bolt at the bottom. Must be a difference between Isekai and Kubota...
2004 KENWORTH 10 WHEELER GRAIN TRUCK (A64278)
2004 KENWORTH 10...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2017 HYSTER H60FT STRAGHIT MAST FORKLIFT (A63276)
2017 HYSTER H60FT...
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
2016 JOHN DEERE 300G LC EXCAVATOR (A65053)
2016 JOHN DEERE...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
