oliver1555
Gold Member
Deleted
The black and white wire (duplex) circled in green goes to your brakes. Both axles or just one? Put an ammeter in series with the blue and black wire circled in red and see how many amps it pulls 7 (2) -16 (4) with the truck brake applied. Put an ohmmeter across the black and white (disconnect one side) and you should see about 16 ohms of resistance. A fairly quick test is jack up one side spin the wheels and hit the brake. See if the tires stop, while holding the brake, does View attachment 807645the tire turn easily by hand?
I’m guessing that your Ram isnt the issue. Does it work with a different trailer?
Great, half the battle. Now all we have to do is follow the black and white wiring trail, probably a bad splice wherever they jumped in both axles ( splices usually on drivers side of trailer) or bad ground point on one of the 2 wiresOn my big GN trailer, the brakes work perfectly. It’s something on the smaller trailer itself.
The small trailer has brakes on both axles.
The brakes do work, but they are weak, like maybe 30% of what they should be.
I dont see a dedicated ground wire from trailer frame to truck so where are the lights and brakes grounded? Hate when they drive in a self tapper and call it good.Thanks. I am going to unload the mowers and try to start looking today. I had a feeling it would be a bad ground or wire splice.
Wouldn’t that be in the 7-pin plug?I dont see a dedicated ground wire from trailer frame to truck so where are the lights and brakes grounded? Hate when they drive in a self tapper and call it good.
Over on the HD Ram forum they say one of the types of 7 wire trailer plugs is incorrect.
In the attached picture the correct version is on the right side.
The 7 pin plug has a larger diameter wire (orange circle) that does go to the truck. One wire goes to the breakaway disconnect switch, one wire to the brake negative side. Where is the trailer actually connected to the truck wire? Probably the one zinc coated self tapping screw after it goes to the first set of brakes. You may find another self tapper (or two) on the rear by the lights.Wouldn’t that be in the 7-pin plug?
They do have a self tapper on the trailer itself
They both will work, the one on the left gets a bad rap because the dual contacts sometimes get too wide. A little tweaking with a small screwdriver can remedy that.Over on the HD Ram forum they say one of the types of 7 wire trailer plugs is incorrect.
The breakaway battery does not provided any braking capability under normal operation.Noticed trailer brakes are weak.
Battery box says “recharge” on battery, but battery is only 2 months old and electrical tester reads 12.4V
Brakes work, but don’t do a lot, even with brake controller fully cranked to 10.
The trailer is only a year old and brakes worked well when I first got it.
What should I start looking at? Wiring connections seem fine
A good electric mechanic needs to dig into your battery issue. It could be the battery has a surface charge but no guts when a load is applied. It could also be an issue with how it is wired causing a repeated drain recharge cycle. Also there could be an issue with the onboard charger electronics in the box—if the box gives you messages it has a circuit board in the box.Yeah should have been more clear: there’s 2 issues
1. Battery box says “recharge” but tester says 12.4V
2. Brakes weak.
No, they haven’t been adjusted, but what would have changed that much from using it for a few months? It only gets used 2x per week. May have used it 15 times since I brought it home in March. The braking power dropped suddenly
