Dead battery, broken exhaust stud, tow ports, gas tanks, welding, carbs.... YIKES!
/ Dead battery, broken exhaust stud, tow ports, gas tanks, welding, carbs.... YIKES! #61
2003 Suburban has 188,800 on it this morning. It's had a non-functioning O2 sensor in the exhaust manifold since we got it 2 years ago. Mechanic said he can:
a) try and remove it and most likely break it instead
b) drill the manifold, weld on a nut, and insert a new one
c) remove the exhaust manifold and install a new/used one, but probably break exhaust studs in the process
d) just drive around with the check engine light on like everyone else.
I chose plan d.
FWIW: I know a few folks that have gone with plan b on this one. Often as plan a, break, cut flush with a die grinder, and then plan b.
On some of my vehicles, having the O2 sensor go out causes a substantial drop in performance. Substantial.
All the best,
Peter
All the best,
Peter
Yes. I was concerned a bit. Mechanic said not to worry about it, as it runs fine so far.
Hope it was helpful. That's we we're here. ;)
2015 Audi A4 Sedan (A59231)
2015 Audi A4 Sedan...
2025 GIYI SE61 61in Sweeper Skid Steer Attachment (A59228)
2025 GIYI SE61...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
Kubota L3300 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
Kubota L3300 35HP...
1964 Mercedes-Benz 190D Car Sedan (A59231)
1964 Mercedes-Benz...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
