MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,240
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
My 2001 model year PT425 battery died. The metal battery hold down strap wore through the case and that was that. As many of you know, on this iteration of PT425 layout, the muffler has to be removed to get the battery out. Four nuts on four studs.... three came off... one stud snapped very easily. Ouch!
Drive to local tractor store... wanted 4 studs, 4 nuts, 2 gaskets....
They had 2 studs, NO nuts, and gaskets at their other location. They'll bring the gaskets from the other place tomorrow. OK. Walk over to True Value and buy nuts. Go home.
Go to AutoZone for battery..... $149.00 Ouch!
Go back Saturday morning for gaskets. O.K. Only spent $20. OK
3/8 of an inch of stud sticking out. Vice grips didn't work. Drilled into it and tried easy-out. Easy-out snapped in half. Ouch!
Decided to weld a nut onto the broken stud and use a wrench to back it out. But didn't want to weld in the garage and didn't want to weld with a tub full of grass clippings and debris. Can't move machine without opening tow ports.... never had to two mine before. Manual says to open the tow ports and connect the bleeder hose that was supplied with the machine.... the bleeder hose only has one fitting. The other end is just a cut hose. I know where the bleeder port is, but can't locate the fittings for the tow ports that the manual says are on the side of the tram pump. Finally figure out the tow ports are just plugged and there are no fittings installed on them for the bleeder hose to attache to... IF the bleeder hose had fittings on BOTH ends, not just one end.... Ouch!
Decide that I need two 90 degree male-male fittings, two caps, and one female fitting on the end of my bleeder hose. Head to NAPA store.
We can't put an end on your Parker hose. We only to Gates hoses. Also, we don't have and fittings that will work. Hey, Bob, do you want to take a look at this? NO! Says Bob. Go over to our heavy truck location 10 miles away. They can help you.
Drive to heavy truck location. Explain to the guy what I need and who sent me.
Was it that bearded %^&$!!that sent you? He knows we don't stock parts here. I hate that %^&$!!
Well, I'm out a 20 mile round trip...
So the guy that hates the bearded guy calls another heavy truck company across the street, sets me up over there, I go over there, they won't put an end on a Parker hose either, but they have all the fittings I need and make me a new Gates hose....
Two hours, 30 miles and $78.00 later, I have a towable tractor.... Ouch!
I install the fittings, the hose, put a ratchet strap on the FEL arms, lift it up an inch and am able to very easily roll the tractor out of the garage.
I drain the fuel tank and remove it for safety. Leaf blower to the tub. Simple green in a spray bottle. Let is soak an hour. Power washer with Simple green, and I have a nice, clean engine compartment.
Put the oversized nut on the broken stud. Roll out the wire feed welder. BZZ BZZ BZZ BZZZ BZZ the nut is welded to the stud. Backs out easily with a wrench while its still hot. Worked great!
Install battery.
Modify hold down strap.
Install new exhaust stud.
Install muffler.
Remove bleeder hose from tow ports.
Install caps on new 90 degree fittings.
Open top bleeder port and wait for oil to appear.
Close top bleeder port.
Open side bleeder port.
Install bleeder hose.
Put other end in tank.
Pull spark plug wires.
Crank engine a few times until no bubbles as per procedure.
Remove bleeder hose.
Install bleeder cap.
Top off hydraulic tank for good measure.
Install gas tank.
Fuel in tank.
Connect plug wires.
Fire up tractor.
It starts, runs 29 seconds and dies....
With no throttle, when I crank engine, fuel shoots up out of carb and belches fire.....
Ouch!
I need a carb rebuild kit and a fuel pump....
Fuel pump has been disconnected for 3 months, so I've been running by just keeping the tank full, which is good for about an hour and a half of operation.... but since I've done all this other stuff, its time to get a fuel pump.
Price fuel pump on line.... about $150! OUCH!! *%**#$(@($!!!!!!!
Hahahaha :laughing:
Install battery.
Install muffler.
Install gas tank.
Fuel in tank.
Connect plug wires.
Fire up tractor.
Ouch!
Hahahaha :laughing:
