Ford 1210 with 3 point that won't go down...
   / Ford 1210 with 3 point that won't go down...
The dead give away was the lift wouldn't move, wasn't putting any fluid thru either port, but it was leaking fluid out of the gasket on the first part we pulled. So, we pulled that think apart again, and everything was as expected to be.
Knowing it was trying hard to make fluid get past that point, we knew it had to be something in the head. Turned out to be the head, or at least its orientation!
Thanks everyone!
David from jax
   / Ford 1210 with 3 point that won't go down... #52
You guys are making me smile with all the knowledge y'all have about this tractor! I really appreciate the help!
. Spent the evening with friends around a fire pit. Didn't accomplish much, but had a good time!
David from jax
Hey Dave I’ve got a 1210 also leaking oil around the injectors how do I fix this-is there a gasket between injector and head-thank you
I would suggest you ask someone who would know a lot more about them than me! I could go to the parts breakdown and look, but this guy probably already knows!
Thepumpguysc@aol.com
David from jax
2000 Ford F-650 (A53314)
2000 Ford F-650...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Killbros 450 Gravity Wagon (A50775)
Killbros 450...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A55788)
2018 Nissan Titan...
