Ford 555
/ Ford 555 #1
Yellow dragon
Ford 555 backhoe
I’m left with a Ford 555 digger (1975-1984). I don’t know where the transmission fluid opening is to add fluid. Please help.
/ Ford 555 #2
If it has the torque converter (No Clutch) shuttle shift the transmission fill is just to the left of the gear shift lever under the floor
It should have a dip stick with markings attached to the threaded cap
ps. a 555 started production in late 1978 IIANM the 550 was built between 75-78 but the service manual covers both models , so very similar units.
/ Ford 555 #3
While you're at it, just behind the transmission fill/check is the rear axle fill/check under an identical 2 bolt cover (if still there).
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
JOHN DEERE 9650 COMBINE (A62130)
JOHN DEERE 9650...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
2019 WACKER NEUSON EZ36 MINI EXCAVATOR (A62129)
2019 WACKER NEUSON...
2026 Hillcrest Trailer 14166SPT 7 Ton T/A Partial Tilt Trailer (A61569)
2026 Hillcrest...
