The one thing that you wonder why you didn't buy sooner?
/ The one thing that you wonder why you didn't buy sooner? #1
marhar
Gold Member
Denton NC
Farm Trac 60
What tools (cheap or expensive) have you purchased and thought why didn't I buy that years ago? For me two come to mind: I went years without a toolbox on my truck. I don't know why but after I bought one I couldn't believe I made it without a toolbox. And a farm jack; the jacks have so many uses.
/ The one thing that you wonder why you didn't buy sooner? #2
For the expensive category my mini x has been much more fun and useful than I expected. For the cheap category a pocket flashlight. I have at least 20 other lights but I use the pocket one multiple times a day. If I end up forgetting it on the charger it’s a legit disappointment.
/ The one thing that you wonder why you didn't buy sooner? #3
Small battery impact like this one. I thought wimps used them. We got one for the shop...younger guys love all the new gadgets. I ended up buying one for myself.
/ The one thing that you wonder why you didn't buy sooner? #4
2nd that about a truck box. My newist favorite - dewalt battery powered grease gun. I have about 7 or 8 or more pump grease guns, all types - mini, lever, pistol etc. They just lay around now. The dewalt with Lucus Red is really all I need - and if not then changing grease tube to say corn silk - is super easy. I can't believe how great battery powered tools are - right behind the grease gun are Dewalt chain saw and pole saw.
/ The one thing that you wonder why you didn't buy sooner? #5
Hope I didn't break any rules - I just started with Dewalt and it just made sense to stick with them so batteries all exchanged. I have had real positive results from all of the 20v tools from them. Not sure how the flex volt range is but can't be happier with the older models I have
/ The one thing that you wonder why you didn't buy sooner? #6
My tractor. For some reason after buying my 60 acre property I thought I could get around without one.
For 2 years I was "getting around " till I thought " enough is enough "
/ The one thing that you wonder why you didn't buy sooner? #7
Ditto on the impact driver (mine is DeWalt as well)
And recently, added a step bit set for the drill bits. Wow....what a difference.
/ The one thing that you wonder why you didn't buy sooner? #10
Tractor with a LOADER. My first 2 tractors didn't have a loader. Power Grease gun #2
/ The one thing that you wonder why you didn't buy sooner? #11
Oh, can't believe I almost forgot...a crane.
After getting a small 8K capacity knuckle boom crane on a Unimog I don't know how I ever did without one. Recently got a 10-ton rotator for larger stuff/heavier lifts, but the little one is used a lot.
/ The one thing that you wonder why you didn't buy sooner? #14
I'm having trouble stopping at one thing but since I got my 4 post lift I keep coming up with new things to use it for. loaded my Miller welder in the back of my truck the other day and the wife just shuck her head and laughed and the easiest set of lawn mower blades I ever changed was on the lift.
/ The one thing that you wonder why you didn't buy sooner? #15
One is an electric grease gun. A second is a product called Race Ramps. They are just drive on ramps but made out of a solid foam. They are just a little longer and lift just a little higher. One reason I like them it’s a pain to use a floor Jack on a modern vehicle.
/ The one thing that you wonder why you didn't buy sooner? #17
tractor, backhoe, Grapple
Good sized garage with concrete floor
MIG, TIG, stick welders, 2 post 10k lift, metal lathe, Knee mill
just one ... I can't do it.
/ The one thing that you wonder why you didn't buy sooner? #20
I like Race Ramps for getting cars into or onto the trailers, but for oil changes and other service I much prefer a lift.
And like Race Ramps, the 4-post can also be used for loading vehicles on trailers. Plus many other things as mentioned by others above.
