BX24 fuel issue
/ BX24 fuel issue #1
Pszotak
BX24
I have a KubotaBX24. Every do often the fuel slows to a dribble and stalls the engine. I solve this by removing the first fuel filter on the underside under the drivers seat and blowing air through the fuel line up into the fuel tank. That is a temporary solution as it is a continuous problem. Does anyone know how to permanently solve the problem ? I though of taking the fuel tank off and putting a bigger diameter fuel line in but the tech. at the dealership told me the injectors would clog up. If I put a larger fuel line in I would add an additional fuel filter right after the tank.
/ BX24 fuel issue #2
The injectors will clog u.??!!!
That’s the biggest load of horse **** I’ve ever heard..
/ BX24 fuel issue #3
can't you just replace the dirty filters?
  • Good Post
Reactions: JWR
/ BX24 fuel issue #4
Have you put an inspection camera down into the fuel tank and had a look at what could be causing the continuously occurring blockage(s) in the filter(s)?
Is there any debris/water appearing in the fuel bowl?
/ BX24 fuel issue #5
The solution is to clean out debris that is in the tank. Sometimes it's a single object like a large insect, or leaf. It could also be a serious microbial contaminated fuel problem. Microbial contamination will look like anywhere from black specs in the fuel and filter, to a thick black slime.
As has been mentioned, get an inspection camera if you can, and see what's in the tank. Also examine the filters. You may need to drain the tank and flush it out.
Report back with what you see in the tank and filters.
/ BX24 fuel issue #6
Can be found on amazon. not a big cost, but will need to use phone wifi for adapter. got mine to inspect bee boxes without opening it up
/ BX24 fuel issue #7
I’ve exactly the same issue and have used exactly the same (blow backwards) solution. I also periodically drain the tank and shove a vacuum down it and suck everything out. It works for a while. I’ve never been able to get the camera (I’ve the model above) to show me anything interesting.
/ BX24 fuel issue #8
I've worked on a BX23 that had this issue. In their case it was just some debris. Not sure what it was, because it was a rubbery type glob of something. No way it would've come out of the fuel hose connector, as that is why it would get clogged up/restrict flow again.
How I fixed it was draining all of the fuel, removing the fuel tank, and then filling it with a garden hose with water and shaking it till the debris came out. I then let it sit for a few days to dry out with a fan blowing into the filler hole to dry up the water. That also included periodically shaking it.
Then I reinstalled it, got some diesel 911 and threw a few ounces of that in it to absorb any extra water with fresh diesel. User was happy.
I told the user that they need to minimally use a jerry can with a mesh filter OR a funnel with a filter, like a Mr. Funnel.
/ BX24 fuel issue #9
You are my doppelganger. How'd this turn out for you, Pszotak? I just posted basically the same situation. I've also been blowing air up the line, watching that slow dribble turn into a nice flow. It gets old. I ordered one of these today and am hopeful I can see what's up, because getting the tank out will be hard to fit into life.
For me, this started happening right after I filled up with home heating oil as opposed to diesel from a filling station. Perhaps home heating oil is much less filtered and there was a dead wolverine in the tank or something.
/ BX24 fuel issue #10
One of my neighbors tried the 'home heating oil' fuel option, siphoning from his heating fuel tank. He had constant problems with microbial issues. I have always used off road diesel fuel directly from a dealer pump and have never ever had a fuel quality problem. Anyone else see a common issue here?
/ BX24 fuel issue #11
I have had the same problem for years, every six months or so. I refuse the massive job of pulling the tank for cleaning. I installed a remote filter kit so I don't have to crawl under the tractor ever again. I modified a spare filter bowl with a tire pressure valve for the new remote kit so that when it happens again I can swap out the filter bowl and easily blow air back into the tank to clear the blockage. I'm hoping that eventually the debris will break down and get caught by the filter. If not, it's so easy to blow out the line, I can live with it forever. Get the coffee filter to pervent future problems.
2021 TAKEUCHI TL12R2 SKID STEER (A64279)
2021 TAKEUCHI...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
(4) 205/75R15 TIRES W/ 4 LUG WHEELS (A64281)
(4) 205/75R15...
213078 (A64276)
213078 (A64276)
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
