Good morning!!!!
   / Good morning!!!! #171,673
no joy on foam cannon, had to order optional wand for pressure washer with 1/4 inch fitting at end
much cheaper than ordering new pressure washer and I like this cheap HF, note the four manufacturers named on adapter, looks like all made by same folks, good name
grands. I put antifreeze in it over winter, so far catches prime quickly.
🤙🤙🤙 I posted before reading this.
   / Good morning!!!! #171,675
She is a golden doodle 7 weeks old 70 percent poodle 30 percent golden will weigh about 45 pounds when fully grown
Oh my, what a cutie. Gonna be spoiled, but hopefully will mind well. My boss has a female Golden, and they just bought a Golden Doodle pup, hoping to have Golden Golden Doodles someday. 75/25 Like Thomas said, I concur, she landed in a good situation.
When I was a kid, we had derivations of Pekinese/Poodle that were called Peek a Poo. They were good pets.
Been busy, mainly on piddly things, but did get about 12 acres cut. My bushhog blades are quite dull. I know this because after a day and a half, my fields already have razor stubble (things sticking back up).
   / Good morning!!!! #171,677
56 jumping to 88. Sky looks so much clearer, but the air quality measures are still higher than normal.
Kil, those are nice looking cabins and saunas. Did you get a wood burning one?
BEF, sounds you need to put up at least a gazebo and/or some Adirondack chairs in the shade for Mrs. BEF.
Got a nice hike in yesterday. Building my mileage back up from when I had my foot problem. Got the kayaks out and cleaned up...lots of dust from having them hanging in the barn...plus mine had a nice wasp nest attached to it. Only one wasp to deal with.
Yes this one:
went with the Stoveman stove. When I ordered the kit almost two years ago, there was a 6 in front not an 8. That project is where I got my carpal tunnel - between the cordless driver and the rubber mallet…
   / Good morning!!!! #171,679
KJc
Have you considered something like
We have, but when we get the recently-delivered shed equipped and furnished and can spend some extended time (like a weekend) we have a spot for the dogs to stay without cramping up our little 10x16 spot.
   / Good morning!!!! #171,680
Got things outside all put away (or covered) + string run around the shelves to prevent the pots from blowing off.
Was juggling some pallets around when Fedex showed up with a partial order from Burgess.
Checked Nest Box No. 3 while I was up that way, we now have 4 bluebird eggs ... (y)
Grabbed 30mm socket for the MMM blades from the shop.
Started to spit rain about the time I got back to the house.
Have the MMM on the forks, just waiting for a break in the rain so I can take them off.
Should be a break in an hour or so.
In the meantime, I'll if I can scare up a couple of pots for those plants Fedex delivered ... ;)
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A58214)
2012 SOUTHERN VAC...
2020 Pratt 8ft S/A Flatbed Tilt Trailer (A56859)
2020 Pratt 8ft S/A...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
