JD400 HYDRAULIC OIL FILTER
/ JD400 HYDRAULIC OIL FILTER #1
Orjd400
Jd400
Jd400 Pump started to whine while using the backhoe. Figured Id try do full service before I burn up the pump if I havent already.
In the oil filter housing was a valve that doesn't appear to me to belong there. I have service manual and part diagrams but both show filter housing different from mine but neither show a valve in this portion of the housing.
/ JD400 HYDRAULIC OIL FILTER #2
That looks like 28
That looks like 28
yes same valve is in the bottom passage which connects to the transmission sump. I think when the filter is clogged it pushes 28 down and flows to transmission. the mystery valve would block that flow. Correction I think 28 is surge valve.
I found the origin of the pump noise, the pump coupler splines have worn down to nothing. The coupler I have t22915 is for tractors:
2030, 2440 s/n -340999, 2630, 2640 s/n -340999, 300B, 302A, 401. I'm supposed to have t22914.
I wonder if the pump is from one of those models?
I ended up leaving out the valve in the oil return filter, I have no idea where its supposed to be.
/ JD400 HYDRAULIC OIL FILTER #5
Your pump needs the T22915. T22914 is for smaller pump with keyed shaft. Yours has a splined shaft. Shaft is most likely worn also and should be replaced if you want coupler to not fail prematurely.
I would like to but my time/funds are limited. The coupler did fit well on the shaft.
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2020 Ram 3500 4x4 Ext. Cab Pickup Truck (A59230)
2020 Ram 3500 4x4...
4ft Mini Skid Quick Attach Rotary Cutter (A61307)
4ft Mini Skid...
