Compact telehandler
/ Compact telehandler #361
/ Compact telehandler #362
Dennis,
I read over on FF that last fall they were freezing production on the Versahandler line. One of the guys over there was in the market for a new CTL for his sawmill and farm. That is what Bobcat told him.
hugs, Brandi
Home - Giant Loaders has expanded to the North American market in 2016 and is building quite a network. It has a good alternative, whether you want a compact telehandler, a telescopic wheel loader, a mini loader, or a mini loader with short boom and increased lift capacity.
/ Compact telehandler #363
Yep, I remember reading about them and there is a dealer in Oklahoma City.
The small Giant:
/ Compact telehandler #364
My local dealer has the compact loaders. They tried to use one of the compact loaders with forks on it to load a rental trencher on my trailer. The operator could not see the fork tips. Had to have another person direct him where to go to get under the trencher. I was so unimpressed, I didn't give it a second look.
hugs, Brandi
/ Compact telehandler #366
hugs, Brandi
I cant see them with my front loader either. Nor on any telehandler i have driven.
/ Compact telehandler #367
hugs, Brandi
One of my buddies had a compact articulated loader. The visibility wasn’t bad but it was worthless for any grading work. Apparently it’s stability wasn’t good either. He ended up trading it for a CTL.
/ Compact telehandler #368
Articulated loaders are cool and all, but I honestly feel that once you embrace the idea that a 4wd/4ws compact telehandler can do basically any and all FEL activities even down to digging, the only thing that would turn me back from the compact telehandler to the compact articulated loader in any brand's showroom, would be if i could not afford the telehandler but could afford the loader. And even then i might wait, or sell something else, to bridge the gap!
I think the point about seeing the 6' forks was partly that if you have long enough forks, you can lift the loader arm and curl down the forks to get them full visible UNDER the loader/fork carriage for your initial lineup/stab.
/ Compact telehandler #369
In Holland it is pretty common to use a loader for grading, whether its a 2 ton compact loader or a 20 ton industrial loader levelling crushed rock roadbase. It does take some getting used to, because you have to plane the bucket on the heel and adjust your depth of cut with the bucket tilt, and slightly lift it when the bucket fills in order to maintain traction.
/ Compact telehandler #370
Here are some pictures from last April pulling Willow trees at the south pond.
Before:
Using the tree puller, view from the seat in the V417:
Clamped on:
Clamped on:
Pulling:
Still pulling:
Got a bunch:
There are no after pictures because I never went back an pulled the rest of the trees (n)
/ Compact telehandler #371
How hard is i to pull them that way?
My TC45 likely has quite a bit less lift vs your machine
/ Compact telehandler #374
I run a Danuser Intimidator on our Bobcat T66 CTL and its a beast! I love being able to dig, cut and pull. Its a very versatile tool.
/ Compact telehandler #375
Moving some red clay with the 72 inch wide one cubic yard bucket to build up a low area:
First pass using the bucket to knock down the high spots:
Drove over the area "Wheel Packing" the dirt:
/ Compact telehandler #376
If I had to do it all over agin, I'd get one of these instead of a tractor.
Only alteratuons I'd make are remotes for a small hydraulic winch I'd rig up to skid with and maybe a taller tire.
These things are beautiful!
/ Compact telehandler #377
Progress on the dirt fill project filling a low area.
Picture from May this year:
First bucketfull yesterday:
And today before first bucket of dirt:
First bucketfull over the hole from tree removal, click this: Compact telehandler
Spread it out:
Next trip dumped:
Needs to dry out some before spreading.
It came from the edge of this pond and has some silt in it:
/ Compact telehandler #378
A rare October ice storm two years ago broke a lot of limbs because the leaves were still on. I got the ones in the yard right away, but there are several more broken limbs out on the property.
Here are two that need to come down:
Clamped on, using the Long Reach Tree Puller:
It broke off when I retracted the boom:
View from the seat of the other one:
Clamped on:
Retracted the boom:
And backed up:
Two down, many more to do. :cry:
Gd4u X.
Seems you have all the stuff you need that a lot of us can only wish we had.
Thats one thing i love abt out where you are. The openness of the lay of the land.
The heat however is an entirely different issue.
/ Compact telehandler #379
Picture from May this year:View attachment 804869
View attachment 804873View attachment 804874
Spread it out:
Next trip dumped:
That a full yard bucket X?
Would take me 3 trips w mine if so.
Guess that’s why l have a 1.5 yd trailer.
These handlers are so super.
Cub Cadet Ultima ZT1 Zero Turn Mower (A64047)
Cub Cadet Ultima...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2002 SHOP 20' FLATBED GOOSENECK (A63569)
2002 SHOP 20'...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
