Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #21
Echo are well made saw...I think the 7310 is probably their best saw. It's a closed port saw. Just like the Stihl and Husky pro saw...all closed port saws.
All the other echo's seem to be open port transfer saws. They are less expensive to make and are considered more of a homeowner type saw.
590 open port...
images
7310 closed port...
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #22
Did you ever find a hard-shell case?
Been looking for one for my 620P with 24" bar.
Nice saw, glad you're happy with it. Love my Echo's
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #23
I really don't trust the stock Echo air cleaner. It has sealing issues where it mounts to the intake baffle. You have 2 choices, get the 'o' ring kit or purchase the foam air cleaner velocity stack from Red Beard or Saw Salvage.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #24
I just added my own o-ring, but it is definitely a design flaw.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #25
You actually need TWO. One on the snorkel and one on the fixing stud on the top of the stock filter.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #26
Thanks, I will need to check that.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #27
Echo 590 620 is a closed port cylinder too. See those upper quad transfers.
Uppers and lowers.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #28
This is open port cylinders.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #29
Even the echo 490 4910 501 saws closed port. Uppers and lowers.
Thank you, i really like the CS7310 saw. Its plenty enough saw for me.
No, i haven`t found a hard-shell case for it yet. So i`m still looking around.
Which model saw are you referring to(?)
I`m not finding any issue at all with the air filter design in the Echo CS7310 saws.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #32
This stihl one holds bigger saws. Guy said he put a 660 in it.
Good grief ! 73cc's ? Holy cow ! My mini bike was 60cc's and my second bike was 100cc's ! A chainsaw with that much power !
LOL, amazing isn`t it!
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #35
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #36
Timber Wolf. Have not even started it yet. Waiting for the Red Beard foam air cleaner and velocity stack and I need to mod the muffler anyway. Reminds me of Stihl's Every Stihl I have, every one needed the mufflers opened up. I may replace the carb with a larger throated one as well.
/ Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #37
00009004010 So it must be big one. One site says. =
Suitable For:​
  • MS 661 – MS 881
Only up to 20" bar, wonder if that is only a limit due to the scabbard length?
Ken, i think you can buy longer scabbards from Stihl separately.
Ken, here you go. Go into the Stihl website, open the menu in there for scabbard length. They go all the way up to 36 inch.
I`m going to go down to my Stihl dealer wednesday and see if they have the large case. I`ll take my saw with me, see if it fits in it ok.
I see in the note section in there, this case won`t work if you have a "wrap" handle.
Went to my dealer Ken, they didn`t have the large case in stock. If i get some extra time, i`ll look for another dealer near me and call them to see if they have one.
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
