Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #21
Echo are well made saw...I think the 7310 is probably their best saw. It's a closed port saw. Just like the Stihl and Husky pro saw...all closed port saws.
All the other echo's seem to be open port transfer saws. They are less expensive to make and are considered more of a homeowner type saw.
590 open port...
images
7310 closed port...
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #22
Did you ever find a hard-shell case?
Been looking for one for my 620P with 24" bar.
Nice saw, glad you're happy with it. Love my Echo's
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #23
I really don't trust the stock Echo air cleaner. It has sealing issues where it mounts to the intake baffle. You have 2 choices, get the 'o' ring kit or purchase the foam air cleaner velocity stack from Red Beard or Saw Salvage.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #24
I just added my own o-ring, but it is definitely a design flaw.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #25
You actually need TWO. One on the snorkel and one on the fixing stud on the top of the stock filter.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #26
Thanks, I will need to check that.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #27
Echo 590 620 is a closed port cylinder too. See those upper quad transfers.
Uppers and lowers.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #28
This is open port cylinders.
   / Echo CS-7310P Pro Chainsaw: Questions & Thoughts & Things You`ve Done With Yours. #29
Even the echo 490 4910 501 saws closed port. Uppers and lowers.
Thank you, i really like the CS7310 saw. Its plenty enough saw for me.
No, i haven`t found a hard-shell case for it yet. So i`m still looking around.
207277 (A52708)
207277 (A52708)
2020 CATERPILLAR 246D3 SKID STEER (A60429)
2020 CATERPILLAR...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2019 Chevrolet Tahoe 4X4 SUV (A59231)
2019 Chevrolet...
