"bushhog" Blade Sharpening
/ "bushhog" Blade Sharpening #1
charlessenf
Gold Member
York County, SC
Kubota B7800
I've a 4' Yellow 'bush hog' type (Maybe Tractor Supply) and never (10 yeas in +/-) even looked at the blades much less sharpened them. My excuse is they are hard to see . . .
How does one get a look at them?
How often do folks replace them? Or sharpen them?
How would I go about sharpening them?
I do not use it a lot - one bottom field I wind up cutting down most Summers - but have neglected a bit and it needs attention.
I have a trailer I suppose I could transport the thing on to get it to a dealer after saaving up for a few months to pay!) but it should be something I can handle once i know where to start.
/ "bushhog" Blade Sharpening #2
This link is one of many threads; I think I saw a more recent one in the past few weeks.
I’ve never sharpened mine; 20 years old.
Can look at the blades by lowering the cutter onto large sturdy wood blocks on at least four spots under the frame itself, then just look (don’t crawl) under.
/ "bushhog" Blade Sharpening #3
Some people stand up one end of the mower vertically with their FEL or forks.
I just raise the 3pt hitch and put some Jack stands under the front of the mower. There’s no way it can lower (unless the top link fails).
I usually take a grinder to the blades to smooth the burrs and chips and pretend to give it an edge if I’m going to be mowing grass. Definitely nothing fancy. One doesn’t want a sharp blade for brush as you want to smash the stalk, not leave a pointed punji stick.
One day I will use the hole that is in the mower deck to access the blade bolts, from the top of the deck, and replace the blades.
/ "bushhog" Blade Sharpening #4
By tightening my top link, then raising the 3 point hitch all the way, when I drive the rear wheels of the tractor up on a stout set of ramps the mower is then a good 3' off the ground (tractor is nose-down). I then put 4 tall jack stands under the frame of the mower, crawl under there with my angle grinder and touch up both blades. And yes, do NOT put a sharp edge on the blades.
/ "bushhog" Blade Sharpening #5
I cheat and use my two post lift...
/ "bushhog" Blade Sharpening #6
Sharp blades cut thick grass much better than dull blades which will beat it up and lay it over as much as it cuts, I load my tractor on my gooseneck trailer take the 3rd link all the way up and lift the mower as high as the 3 point hitch will allow, back the tractor up until the mower is hanging off the trailer and I can walk right up underneath the edge and sharpen the blades with a handheld grinder, I do take a fence post and place it up under the deck of the mower in case of hydraulic failure. The blades don't have to be razor sharp to cut good but a nice edge will drastically improve your finished cut.
/ "bushhog" Blade Sharpening #7
Indeed this is another way. Just got to think out of the box a bit.
I like my blades sharp and always cut in a way that causes me to "recut" what I previously cut in the prior round. I mostly use this unit to top cut the pastures.
I have an older unit with no tail wheel that I use for cutting small trees etc.
/ "bushhog" Blade Sharpening #10
Just sharpened the blades on my new (to me) brush hog. It came with my newer (lightly used) Kioti tractor in a package deal, but I didn't need it for the first couple summers, until now.
With my hydraulic top link, I can actually tip the sucker way up into the air. I put jack stands under the edges like others have recommended, then just lay down and sharpen with my angle grinder. Only takes 10 minutes.
My blades were already in good shape, but I like when it cuts the grass, instead of rips it, pulling it, bend it over, etc.
/ "bushhog" Blade Sharpening #11
I will note that I went pretty sharp on this go round. Probably too sharp. Then made some new trails in the woods and took out many large 1-2" stemmed bushes and saplings. As well as accidentally got into the dirt/ground a few times, as often happens by mistake when navigating rough terrain. All done brush hogging last night so I took it off, and quick looked underneath first. A few big dents in the blade edges, whoops. Making the blade edge real sharp does mean it will get damaged more easily. But it was cutting grass in the field better than my John Deere riding mower does!
/ "bushhog" Blade Sharpening #12
My Woods brand bush hog is about 45 years old and I use it roughly 20 - 30 hours per year. In 1990 or so I took the blades off and sharpened them. I didn't notice much difference to the cut so haven't touched them since then. If it ain't broke, don't fix it!
/ "bushhog" Blade Sharpening #13
That's a gloat, no?
Not necessarily a gloat but if it is seen that way there is not much I can do about it.
I bought this lift 15 years ago for $1,799.00. I have not had any funds go into it so the cost is $120/year. That come to $10/month at this point or less that two cups of coffee per month.
I just have so many people say they wish they could afford a lift. I think more how can you not afford it. I see it as an investment in being able to take care of your machinery in a comfortable way.
One tip though, do not buy a 9000# model as I did. Consider getting a 12K unit to lift heavier vehicles. I get a little stressed when lifting a 7500# vehicle as I would like a little more margin and not have to ask what is in the bed/and or are both tanks full of fuel... :) Do not get into the same predicament as I did.
/ "bushhog" Blade Sharpening #14
I don't sharpen mine. But I'm not looking for a clean lawn cut on grass. I'm cutting too much junk weeds, brush, etc, to worry about what the grass looks like. Most customers don't care, and I'm only hiring out to cut pastures, not lawns.
I use my riding mower to cut my lawn at my own place.
/ "bushhog" Blade Sharpening #15
I especially like post #10!:)
/ "bushhog" Blade Sharpening #16
Mine has 75 hours on it. Still looks good. Don't mess with success.
/ "bushhog" Blade Sharpening #17
…but with a hydraulic top link, your safety is now dependent on maintaining hydraulic pressure in the top link cylinder (even with tractor off). If a hose fails, or something (animal, kid, a meteor from space, whatever, etc.. ) bumps the hydraulic lever, the rear of the mower is falling down.
To me this is similar to working under a raised FEL. You’re safety is dependent on hydraulic lines. Chances are it WON’T fail or the lever won’t get accidentally bumped when I’m under it, but I still avoid it.
Then again, is that any different than depending on the hydraulic brake lines on your truck? 🤷‍♂️
Safety Police signing off now. 2cents.
/ "bushhog" Blade Sharpening #18
I had jack stands under the mower….
I get that it could rotated back over them, but the stands were basically under the center of gravity. IE not gonna crash down. I think.
/ "bushhog" Blade Sharpening #19
Don't get me wrong, I do appreciate the safety policing. Would be incredibly dumb to injure or even kill myself just trying to do some basic equipment maintenance. My wife and kids would be screwed without me!
/ "bushhog" Blade Sharpening #20
That's how I do mine, but I add a 4x4 under the back edge. I notice you don't have a tail wheel? How does that work out? I was thinking of adding casters on the front on mine and just running it on the ground for my smoother areas where I'm basically using is as a finish mower.
2016 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Truck (A61568)
2016 Globe Trailer...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
Great Dane Van Trailer 1989 (A61307)
Great Dane Van...
