Tinhack
Elite Member
- Joined
- Jul 3, 2020
- Messages
- 3,594
- Location
- Lytle, TX
- Tractor
- Ford 3910, John Deere 420C, Kubota G32XKS, IH 2606, Bad Boy Maverick-60"
Lets be serious here. Most of the CUTs and SCUTs need something in the rear. Most don't have 30" between the tires and you can raise a tire by just leaning on the ROPS. If you need traction, add tire ballast. If you need stability, add wheel spacers. If you're adding weight because the FEL is raising the back tires, you're abusing your tractor. These tractors are not meant to move a lot of dirt--They are lawnmowers with a little more power. And not much more of that. They were made to move flowerpots around on an estate, not for farm or dirt work.
