Stihl ms290 not oiling enough
   / Stihl ms290 not oiling enough #22
Can’t download that. But I have the paper manual :)
Wohoo! Definitely was the problem. Valve is clean and oil is running out like normal. Thank you so much. I thank you, my bar and chain Thanks you and my family thanks you for being able to be warm next winter!
   / Stihl ms290 not oiling enough #24
Good. I make sure to blow out the vent every time I clean the saw because it's sits at the most dirty part of the saw.
I will cut 10 cords by June 15th and put the saw away for the year. I never knew about the vent. My saw looks brand new, it is a 2008. I leave it full of chain lube for the time off, I think I am not going to do that going forward and then on first use blow out the valve.
It should have been obvious to me. Every time I would start the saw and check if it was oiling it would come out no problem. Then in a few minute the vacuum would build and nothing…
   / Stihl ms290 not oiling enough #26
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
1629 (A57192)
1629 (A57192)
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
Deere 335P (A53317)
Deere 335P (A53317)
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
