House Build 2023
/ House Build 2023 #21
Here were the 3 options on front doors. the windows above are open to the vault in the great room and the sills and top caps will blend in as much as possible they won't be so garish.
Single 42" wide, single with side lights, 2x36 wide all 8' tall.
I have double doors in the front of my newer home. Absolutely love them. Especially for moving furniture in, and the aesthetics from the road on a larger build. It's in northern Minnesota, and don't notice any colder floors than a single door.
/ House Build 2023 #22
We did a single door with two sidelights which has a similar effect. But we get the better door seal/thermal performance vs double/french doors.
That said, we do have french doors out back to our screened porch, so obviously I understand the desire for the double-door :)
/ House Build 2023 #23
Of the three door options, in my home, I'm going with the 42 inch front door. I've never been in a house with glass on the side of a front door that I liked. To me, it's a 90's fashion thing that isn't done very much anymore.
You mentioned that those windows over the front door wont be so "garish", but in your pictures, they are overpowering and very, VERY busy.
Home design, colors, and materials are just like clothing fashion, but instead of changing every year, they seem to change every decade. There are things that become popular and everyone does it, then it goes away and we all wonder what everyone was thinking. Glass tile seems to be the thing that nobody is doing anymore, but they for awhile, it was everywhere. Right now, the trend in tile is white subway, and fake marble. I think it's important to be sure to do what you really like, and run away from all the latest trends.
If it was me, and I was building your house, I would think seriously about the window in the gable on the left of the house, and those three windows above the front door. You have changed the porch and it's not so overpowering, but I think it still needs attention. What does it look like without the open gable and just extending the existing roof down over the porch area? Or maybe a maybe just a smaller gable porch that just covers the front door area?
You have one of the best floor plans that I've seen. Before you build, be sure the exterior is just as good.
/ House Build 2023 #24
Pay the premium for the underground electrical feed, you'll be happy you did.
I'm a big fan of double front doors. Ours rarely gets used but when you need to move something big and bulky they make life easy. They also look better than a single with sidelights.
I ran 400a underground service to a stand alone meter, then ran separate feeds from there to the house, garage and shop.
/ House Build 2023
Maybe you just worded this different than some of the others commented but this makes good sense. I'll ask the engineer about this option when I talk to them.
/ House Build 2023
The windows in the front are my wife's call. The roof was changed to make the vault in the great room possible. So the roof can't just follow down or it would not allow the vault inside the house. She wanted it to run that direction, it was running E-W with the run of the base roof but she wanted it rotated so you walk in under the tallest part. Originally she wanted the middle gable to be totally glass. This is a much better option in my opinion.
The window on the left gable is functional for the room behind it. It's the only window in that room.
I understand what you are saying and I probably would have done it a bit different if it was just me. But I want her to be happy and have a say in it also. All that and I will add, we are driving this by what we think is what we are going to like the best and not letting trends factor in. I'm sure we will look back and see several things we would do differently if we had it to do over but I think the big parts are going to be just fine.
/ House Build 2023 #27
We ran our electric underground. About 1200 ft frm the road. Separate access from the drive. Drive is about 1800 ft long. Over head would be 20 or 30 ft access width, underground, 10 ft. Because of the distance from the road, transformer was set at house area. Actually it is set about 30 ft from the storage workshop building, with the meter panel there, like Eddie's picture above. That meter panel has 2 breakers, each 200 amps, 1 for house and garage, the other for the workshop/storage building. House is another 200 ft from that meter panel. Jon
/ House Build 2023
/ House Build 2023
Pad is ready and the driveway has been excavated and 1 lift has been added. Got a lot of rain yesterday so it may be a few days to get the 2nd lift on it. Hopefully 2 lifts will do it.
/ House Build 2023 #32
Wow, getting started right away! Love it. Best of luck to you in this substantial endeavour. Nice house plan, nice parcel of land. :)
/ House Build 2023
I just had a chance to watch your video of the dozer. It's really nice seeing the dirt curl over in the blade!!! One of my favorite things to see.
Thanks. I only have a few hours experience on a dozer. I've been having to learn by the seat of my pants. If I go about half as fast as the slowest speed I can almost keep up with the adjustments so I don't loose the cut or gouge too terribly deep...
I did make it harder on myself by pushing all the dirt off the pad. I should have kept it within the pad. It made it really hard to find the ground again. Both to clean the dirt off the grass and to find a reference for how deep I needed to cut when i went back the other way to clean up what fell off the other side of the blade.
/ House Build 2023 #34
I understand. My dozer wears me out. I can't see both ends of the blade at once, and in just a second, it will do something on the other side that I didn't see and mess everything up. I really need three arms to run it, and after a few hours, I'm totally worn out!!!
/ House Build 2023 #35
If you can, put a man door on the outside of the garage somewhere. So if you have any work space in the garage you can go in and out without opening the car door or going around through the house.
It's probably too late to change but I didn't appreciate how useful a mud room is until I bought my current house that has one. Its not large but its convenient to go in and out that way especially when its raining or snowing. I can take my boots off and leave them in there rather than tracking mud in the house or taking them off outside.
/ House Build 2023 #36
^^ Very important suggestions from Eric. We also use our mud room, which has a door between it and the house as well, as a sort of "air lock" in the deep cold winter months and also the hottest summer days. And also to keep the dog from running outside to greet visitors, they can instead step into the mud room, close the outside entry door behind them, for a controlled entry.
/ House Build 2023
I would have liked to have a mud room but it was not in the cards for these plans. We are too far along to change them now and even if we could I'm not up for another round of plan changes. Every thing that gets changed on the plans effects something else, it gets exhausting.
/ House Build 2023 #38
Definitely needs man door for garage, even if to the front porch, but ideally by the garage doors.
/ House Build 2023 #39
I decided not to put a walk through door in my garage because it took would take up more room then I wanted to give up. My 3 car garage is 30ft deep and 42ft wide with ten foot wide doors. In my opinion, I'm good with opening the garage doors with the keypad if I need to get in there from the outside.
/ House Build 2023
I'm the same. I never even thought about a man door to enter the garage, now that it's been suggested I see how it would be handy. I have a use for the space it would take up so I'm going to push forward without it, may regret that later but I'm sure it won't be the only thing.
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
(6) 250 Gal Chemical Containers (A64127)
(6) 250 Gal...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
