3 point hitch arms surging
/ 3 point hitch arms surging #1
BruceS_55
RK25
I’m not sure surging is the right word. Anyway, today I was was doing some rotary cutting and after 45 minutes or so the 3 point arms started lifting and dropping and inch or two with no input to the control. I shut down and checked all the houses for leaks and for broken or damaged linkage. I also checked the rear remote controls since I had had a previous issue with the hitch not lifting and it turned out that I had bumped the control with the detent into the detent position. The fluid level was fine. When I started the tractor back up, the issue had stopped and it was working fine. Has anyone had this issue or know what may have caused it?
/ 3 point hitch arms surging #3
Does your model of tractor have draft control? If yes possible you were operating right at the edge of where the draft would engage and disengage. Raise or lower implement just slightly and problem could go away.
No draft control.
/ 3 point hitch arms surging #5
Did you ever find a solution to this Bruce? I have the same issue.
/ 3 point hitch arms surging #6
Did you ever find a solution to this? I have the same issue.
/ 3 point hitch arms surging #7
Small piece of trash/metal in lift piston seal. Filter will catch it after it passes through.
2009 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2009 MAC 35ft...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2022 EZ-GO ELITE...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2000 Ford E-350 Shuttle Bus (A64194)
2000 Ford E-350...
