Backhoe BT751 weight? Removing Boom cylinder.
/ BT751 weight? Removing Boom cylinder. #1
joea99
Marbletown NY
Kubota B21, JD 240GT
Can someone supply the weight of the BT751 BH? I need to lift the boom enough to swing the boom to one side, so as to remove the boom cylinder for servicing. This is a backyard deal, not a shop floor, so I am improvising.
The swing cylinders are already out, so it should swing easily (sure) once the weight is off. I am a bit concerned about the unit tipping if I do that though.
/ BT751 weight? Removing Boom cylinder. #2
Hi Joe, this might be a little late to help you, but I found a weight of 892 pounds for the BT751.
KUBOTA L3301 TRACTOR (A62130)
KUBOTA L3301...
2015 JLG Skytrack 8042 (A60462)
2015 JLG Skytrack...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
HEAVYEQUIPMENT TOOLS (A60736)
HEAVYEQUIPMENT...
