how much if ask a welder come to your home and weld a 2" length small metal plate?
/ how much if ask a welder come to your home and weld a 2" length small metal plate? #1
Jack Yuan
Changzhou, JiangSu, China
Jinma 504, Jinma 904, DF1604, YTO X1804
Hi everyone, I would like to have a investigation. How much if ask a welder come to your home and weld a 2" length small metal plate on the attachment you there? Not in China, but the cost for this service in the US.
That's small work for me, less than ten minutes. But not easy for someone doesn't know welding.
/ how much if ask a welder come to your home and weld a 2" length small metal plate? #2
In China? No idea.
It's not about how easy or hard it is, it's about the equipment costs, transportation costs, time to get there, set up, prep, weld, pack up, hopefully get paid in cash or a check that doesn't bounce or suck up the 4% credit fees, etc.
In China? No idea.
Not in China but you there.
/ how much if ask a welder come to your home and weld a 2" length small metal plate? #4
Always probably cheaper if you take the plate & attachment to them & let them do it at their shop while you wait. Limit (if you know how to weld) would be cost of a welder/grinder/wire or electrodes/& a wire brush at your location (assuming you have the power connection). My guess total cost under either option is lower in China than US.
/ how much if ask a welder come to your home and weld a 2" length small metal plate? #5
I wouldn’t even show up for less than $150, that’s if it’s pretty close. The actual cost to weld would be figured out in addition to that but if the customer did all the prep and it was ready to weld it would probably be another $50. If I have to prep it could easily be another $150. Basically $300 to show up and work for an hour, after that it’s probably $50-75/hr depending on the work.
Good to know, thank you for the information. I think this is the price in GA you there, the price could be similar in other states?
/ how much if ask a welder come to your home and weld a 2" length small metal plate? #7
different parts of US different prices. In Silicon Valley, CA no one is going to look in to your direction for less than $800, just to begin with.
I learned to weld, with flux core mig welder it is easy. $200 HF welder, welding mask $25-50 and other things around another $50-100
For $300-400 i'm set for life.
/ how much if ask a welder come to your home and weld a 2" length small metal plate? #9
That's higher than I expected. I'm glad I manage to weld well enough for my own needs.
It appears I've saved a royal fortune over the years.
I admit I have had friends who weld better than me who have helped over the years.
/ how much if ask a welder come to your home and weld a 2" length small metal plate? #10
duplicate
2019 PETERBILT PB520 GARBAGE/SANITATION TRUCK (A59823)
2019 PETERBILT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2019 Toro Dingo TX525 Mini Skid Steer (A60462)
2019 Toro Dingo...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
