150 years worth of Gopher mounds
   / 150 years worth of Gopher mounds #61
Relax my friend, the gophers are there to stay! You have the perfect soil and temperature. I know it is the same as mine. Every reply with a solution to you problem will work. However, it's only temporary. They always return and you ending spending way too much all the remedies for only short term results. You will end up having to repeat remedies every couple of years. You can raise successfully raise hay, you just have to find a hay man that will cut and bale the hay on the field as is. They will charge a little more for the inconvenience of the bumpy ride and the extra blades that they have to use. My hay field is 40 acres in southern Brazos county Texas and I now can make money off my hay field just let it be don't try to beat nature it always ends up on losing money.
   / 150 years worth of Gopher mounds #62
And that is why the Wild Pigs continue to multiply
   / 150 years worth of Gopher mounds #63
Wouldnt poison be transferred to the hay and be fed to what/who ever eats it?
   / 150 years worth of Gopher mounds #64
High fence and a family of coyotes inside.
Bruce
   / 150 years worth of Gopher mounds #67
Check these websites out for solutions to take care of your little
friends! They like sun flower seeds so maybe peanut butter,borax
and the sun flower mix would take care of them???
willy
   / 150 years worth of Gopher mounds #68
After I rid myself of the first batch of gophers using the Cinch traps I did have a few return over the next year. Didn't take long to get rid of those.
But I've been gopher free for over 3 years now.
   / 150 years worth of Gopher mounds #70
For proper gopher eradication cultivation works very well.
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2022 CATERPILLAR 299D3 SKID STEER (A52709)
2022 CATERPILLAR...
2015 Komatsu WA380-8 Articulating Wheel Loader, S/N A74124, PIN# KMTWA130CFNA74124, Diesel Engine, (A59076)
2015 Komatsu...
BAYSIDE TRI-CYCLE (A58374)
BAYSIDE TRI-CYCLE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
