Tractor for land clearing and preparation
/ Tractor for land clearing and preparation #51
wow that disk is something else to pull
Yes it is. There are smaller ones still heavy enough to chop up stumps and tree stems.
My main point is 300 acres is little to much for low horsepower lightweight gear. Both time wise and job properly done for putting the land into cultivation. This will also apply for working the land agriculturally.
The original members of my family that came to Canada cleared many acres but it was a long hard process. They first killed the trees by cutting a circular strip of bark off of the tree, waited a few years and used axe’s/saws to fell the trees. Then four horse teams to pull stumps and a single bottom walk behind breaking plow followed by disks, harrows, rakes and hand labour to pick roots. It was a tedious undertaking. There were no tractors.
/ Tractor for land clearing and preparation #52
I get it and I have the same thoughts...
I know its crazy the work that was done so so little.
/ Tractor for land clearing and preparation #56
Do not buy a dozer to clear land. It's probably the very worse machine for clearing land ever used. Years ago, they where popular, but labor and fuel was cheap, and everyone had a big dozer sitting around to use.
The only thing that is effective at clearing land is an excavator. The bigger the better. Do not even try to clear that much land with anything under 20 tones. That would be the starting point. It's big and powerful enough to take out any trees, and fast enough to make it worth your time. If you can find a 30 ton machine, that would be even better.
What everyone seems to be missing is what do you do when the trees are out of the ground. It's easy taking them out, it's very hard getting them to the burn pile. A dozer with a root rake takes forever to take out a tree, but when the tree is on the ground, it's even worse at piling them up to burn. Even with a rake, you will get massive amounts of soil in your burn pile. The dirt slows down the burn, and it builds up so quickly that you will be left with mountains of it at every burn pile to deal with. The excavator can pick up the entire tree, root and all, and put it on top of the burn pile. This way it burns cleanly and quickly.
That would be step one.
Depending on your soil, what you want to grow, and how much time you have, you can sell the excavator and buy a dozer to clean up the land after it's cleared. A dozer is good at this. The bigger the dozer, the faster you will get it done. Mine is 170 hp, and it's pure torture after a few hours, but it does move a lot of dirt fairly quickly.
Once you have the land graded, then you can sell the dozer and look into buying a tractor to farm the land. Not knowing your crop, or how much time you will have to till, plant and harvest your crops, I would suggest starting out with something over 100 HP with 4 wheel drive. It doesn't really what brand you get, at that size, they are all pretty much the same. Just buy something that you can get parts for when it breaks down. The more HP you have, the bigger the implement you can use, and the more you can get done in a day.
Avoid shortcuts, and especially anything that looks like a neat or clever idea. Stick with what's been proven to work, and what is used on big commercial operations.
/ Tractor for land clearing and preparation #57
So, as a way of rewording the OPs question (based on what he told us); if all you had was a 75hp 4wd tractor with loader; how would you go about clearing 1-2" thick brush over 300 acres; with "unlimited time", with the end goal of culvivating crops, while not taking out loans.
I would get a heavy duty bush hog; mow down a 5 acre square, then run the heaviest disc I could get my hands on over it multiple times, from multiple angles.
I would then run a rake of some sort, or maybe a chisel plow to cut and pull roots to the surface.
I would try to push the debris in about 8 ft wide windrows, about 24 ft apart; and burn them.
I would look for old heavy impliments locally such as 8 ft off set disc; 3 bottom plow; 3 tooth subsoiler; and use what I could find.
I would probably fabri-cobble together something heavy and steel, and drag the he'll out it. It could be as simple as a couple heavy chains and some I beams or rail road rails; or even a fairly round, heavy log.
And if affordable, I would hire some local day workers to pick roots.
If the 1st 5 acres goes good; I would temp seed 1st 5 acres with a fast growing cover crop and attack the next 5 acres. If the 1st 5 acres takes 3 weeks-3 months; and yields unsatisfactory results; I would adjust my original plan.
If it was primarily vines/briars; I would attack it a bit different; I would 1st; box out a 5 acre square with a 12 ft wide fire break; I would then spray a broad spectrum herbicide on that 5 acres; I would then wait 3 weeks; and about 48 hours before a good rainy forecast, I would start multiple fires in the dead vines/brush/briars. I would then assess the results; and remove stumps/roots as above; But I would be willing to plow/disc/chisel Around the odd stumps.
If it was more of a mesquite type environment, with tougher brush/trees, but spaced more widely; I might try: run a bottom plow or dig/cut wide roots around 75% of a single "tree", wrap a logging chain around the base; and pull individual "trees" out. I would then disc/chisel once I had a 5 acre square "cleared" and plant a fast growing cover crop.
If it was giant hog nettle type stuff; I would start by cussing the man who sold it too me; then spray; and disc; while in full long sleeve everything, and an enclosed cab machine.
/ Tractor for land clearing and preparation #58
It would be pretty hard to consider a dozer the worst land clearing machine. A dozer beats the heck out of a tractor for clearing. A dozer benefits greatly from having an excavator to knock over larger trees and to stack taller burn piles but an excavator is pretty bad at transporting brush longer distance and isn’t very good for leveling up the stump holes. Throwing a whole tree on a burn pile might be easy enough but when it’s been logged and you’re left with 50 million pieces of brush a dozer to gather then up is the only real option. An excavator isn’t very good at clearing 2” trees either. If you don’t have a pretty good thumb setup a 2” tree is hard to grab and even if you do pulling every tree separately takes forever. It’s way faster push out a 10ft path at once.
/ Tractor for land clearing and preparation #59
Given the vastly different tasks here, I would contemplate what you really want to do. Clear land or grow crops. Clearing 300 acres is a large area to do alone with a small to mid sized tractor. I would likely try to hire out the clearing portion if raising crops was my goal.
300 acres of saplings is a lot of biomass to dispose of. You need a plan just for that. Burn, mulch, or a huge slash pile all have drawbacks. If i had to do it myself, I think I would personally mulch it first, then move the mulched material into a set aside area and then remove roots/stumps. Of course, seeing pictures may change that. It may be better to use an excavator and pull them up by the roots. I would also break it into sections and do 5-10 acres at a time. This will be slow or expensive no matter which way you decide.
/ Tractor for land clearing and preparation #60
Mulchers just make a mess. Mulching is really only a good option if you plan on waiting years before you do any ground engagement work and you continue mowing it for those years. Sure you could mulch 2 inch trees or a heavier duty bush hog could do that. But the stumps are still in the ground. How to you plan on planting with thousands of stumps and a thick layer of tree mulch on the ground? You’re still going to have to rake it with a dozer. You might as well start with that option and save the cost of mulching. And land clearing is expensive. You’re delusional to think you’re going to get it done for only a few dollars an acre. Bigger equipment cost less to do the same job as smaller equipment. It wouldn’t exist if it didn’t. It took me like 10 minutes to rough in this driveway on my dozer. How long would the same job take with a small tractor? View attachment 798714
Rent a mulcher to clear the land then get a sub soiler to grind up roots and rocks in place and push the leftover mulch below the soil.
Mini Margaritaville Truck (A55853)
Mini...
2024 Linx 7'x20' Trailer (A60463)
2024 Linx 7'x20'...
2014 Freightliner M2 106 T/A Terex Commander C6060 60ft Digger Derrick Truck (A60352)
2014 Freightliner...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
