Hydraulics
/ Hydraulics #1
Fornshell
JD2240
Hey Tx Jim, Hearing different ways to check Hyd/ Trans fluid on a JD 2240. What is the proper Way.
/ Hydraulics
Dipstick behind your right heel sitting on tractor.
/ Hydraulics #4
Does the tractor you're asking about have screw on cap or plastic handle? I was taught to check JD utility tractors built from '65-'92 with engine operating at idle speed, dipstick nut resting on threads. On later models push plastic knob into tube. I searched one 2240 operators manual # 71859 & couldn't locate answer to your question.
/ Hydraulics
Plastic push in dipstick.
/ Hydraulics
It has the plastic handle push in dipstick.
/ Hydraulics
Cold or operating temperature.
/ Hydraulics
Ok, thanks for your help.
Trimmer/Mower (A65579)
2001 MACK RD688S ROLL OFF TRUCK (A65643)
2001 MACK RD688S...
2019 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2019 ROCK SOLID...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2015 JET 42' ALUMINUM HOPPER BOTTOM TRL (A64277)
2015 JET 42'...
Morooka MST 2200V Tracked Truck (A62679)
Morooka MST 2200V...
