Good morning!!!!
   / Good morning!!!! #168,971
So here is dads lynch pin.
A bolt, washers, wire, hose clamp.
He said he kept losing the lynch pin.
The problem was the L5030 has larger cat2 arms and the mower had cat1 pins. There should have been sleeves in the tool box, so I went to TSC and picked up a few.
Impressive
   / Good morning!!!! #168,972
That’s what I’m talking about!!!!
BTW I misspoke the other day - 4-way not 6-way blade. Still better than the knackered scrape blade I have for the tractor!
I feel better now because I don't have a 6 way blade!! But you will be fine without it
   / Good morning!!!! #168,973
By the looks it work well.
   / Good morning!!!! #168,974
You may want to replace the special Lynch pin with a bolt for the bucket because it is easily lost when using it to do tree work and Kubota wants lot money for it. The standard TSC pin is not nearly as strong as the Kubota Lynch pin.
   / Good morning!!!! #168,975
I’ve seen worse.
heck - I’ve done worse!
   / Good morning!!!! #168,976
How about a tether on the pin? Or a carabiner Instead of a pin?
   / Good morning!!!! #168,977
So next trip starts mid May and includes Sweden where she will have some free time. Here is a link for possible things to see and do that she is looking at. She has been there before so she has a better idea of what to spend time on. Drew, your landlord lady may have ideas too?
   / Good morning!!!! #168,979
If you keep the Lynch pin on a tether and loose the long shaft for the bucket you are out some money. Lost one shaft and discovered one half way out before loosing the second one.
   / Good morning!!!! #168,980
I fully expect to start harvesting lynch pins any day. Sure have lost enough of them these past years and they have to be n the property.
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
6ft Teakwood Cowboy (A57454)
6ft Teakwood...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A57453)
2015 Freightliner...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
AGT Hot Water Pressure Washer (A57453)
AGT Hot Water...
