Silver bearing soft solder strength
/ Silver bearing soft solder strength #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Because of a silver soldering thread in this forum I thought it might help if I posted this here. Because silver bearing plumbing solder is now widely available in hardware stores folks should know about how strong 95/5 tin/silver soft solder is. And how some companies will publish information that makes it seem stronger than it is.
The 95% tin, 5% silver soft solder has a tensile strength of 3600 PSI. That's the yield strength, which is the most important number. If two pieces of steel 1 square inch in area are joined with 95/5 tin silver solder and pulled on they will start to pull apart when 3600 pounds of force are applied.
The shear strength is much higher, about 10,000 PSI. So if the same joint was pulled on sideways it would take 5 tons of force to start the joint moving. Some companies will say their solder has this high number of strength implying, but not explicitly saying, this is the tensile strength.
But even though silver brazing alloy is more than 10 times stronger than 95/5 soft solder it doesn't always need to be used. For example, if you need a really long drill for a wiring job then drilling a hole in the end of a long steel rod and then soldering the drill bit into steel rod will work fine. Just make sure the hole is very close in size to the drill shank because the solder loses strength if it too thick. I have made many drill extensions like this in my career as a machinist.
If you do decide to use plumbing solder make sure it is the 95/5 tin/silver alloy, not the tin/antimony alloy.
Eric
/ Silver bearing soft solder strength #2
will it withstand hyd line pressure on a tractor repair?
/ Silver bearing soft solder strength #3
What about the silver solder that comes in little flat bars ?
/ Silver bearing soft solder strength #4
Interesting. What is the comparable tensile strength of the tin/antimony and tin/lead solders?
I used to silver-solder copper pipes in an earlier life. For hyd lines, I have preferred to steel-weld, but brazing has worked OK, too. The latter avoids pinholes that are easy to get with steel welding.
/ Silver bearing soft solder strength #6
That sounds like silflos that was only good, very good for copper to copper not dissimilar metals.
Okay, thanks. I use the other you mentioned on radiators.
/ Silver bearing soft solder strength #7
There have been enough changes and variations in even solder used for "lead free" copper pipe that you have to specifically look at what you're buying relative to what you intend to solder. Even then, be careful of marketing that tries to sell you a cheaper knockoff.
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
Chandler Equipment 20' Litter Spreader (A60462)
Chandler Equipment...
500BBL WHEELED FRAC TANK (A60736)
500BBL WHEELED...
2008 KALYN SIEBERT TRI PLEX FRAC PUMP (A60736)
2008 KALYN SIEBERT...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
1449 (A57192)
1449 (A57192)
