Front-End Loader Tooth Bar
/ Tooth Bar #1
AB4D
Shallotte, North Carolina
Prior: Kubota BX-23, Kubota L3430HSTC, Kubota ZG23, L3560 HSTC Limited Edition, Current: L6060 HSTC
What's everyone experience with the latest bolt on Tooth Bars? Searching for a tooth bar for a new tractor. I had a great tooth bar on my last tractor using a Kubota light duty bucket I never lost a tooth off the bar or damaged my bucket. Lots of hard use and rocks. However, I can't recall where I purchased the last one from almost 20 years ago. Again, same size of Kubota tractor, with light duty bucket, LA-805 loader.
Shopping around I see low priced ones from VEVOR (China) one size fits all and that will require side spacers or washers, and more expensive built to fit bars from a few well known implement companies. I moved a few years ago, and the ground here is sandy with lots of pine roots and vines.
Thanks
/ Tooth Bar #2
I have a Rankin tooth bar. It came with clamps to secure to the bucket. I did away with the clamps and bolted it directly to the bucket. Bought it thirteen years ago - very heavy duty - works great - $430.
/ Tooth Bar #3
I had a Piranha from BXpanded on my last tractor, and I really enjoyed it. Eventually I plan to add something similar to the Kioti.
/ Tooth Bar #4
I Bought the VEVOR toothbar to fit my 713/4" inside measure bucket. They said theirs measured 711/2 inches. Did not!! Actual measure was 727/8 outside edge to outside edge. I chose to not return it, and cut and rewelded side bracket to get it to fit. In addition managed to break one of the cast steel replaceable teeth trying to install. Had to wait almost a month for a replacement. Would not recommend their toothbar. Mine seems to work ok but took a lot of grief to get it functional.
/ Tooth Bar #5
I recommend the Wicked Toothbar, quality and service is top notch. The site explains how to measure your bucket which you provide when ordering so no probleem with it fitting correctly.
/ Tooth Bar #6
I second that. I have one and what a difference it makes in bucket digging capability.
/ Tooth Bar #7
This looks like a MUCH better way of attaching it than the tabs on the ends I've seen on other tooth bars. Does anybody know why they're not all attached this way?
There are through holes in the edge of my bucket, and I guess maybe the edge is a harder grade of steel. Do most buckets have holes near the edge? I don't know what the holes are for. I've never seen anything from NH designed to fit them. I did get a urethane bucket edge, and specified holes in it to fit mine for attachment (which worked great).
/ Tooth Bar #8
You can try this place....
I have purchased 3 different tooth bars from them. All three worked perfectly. If you go to the menu on the left, they will also make custom sized / number of teeth.
All three times that I ordered, had the bars at my door within 4 days!
/ Tooth Bar #9
Smallchange - RE: toothbar attachment. I would guess most are designed for easy/quick attachment and removal. I would just bet - after 13 years being attached to my bucket - a cutting torch would be the only way to quickly remove the toothbar.
There are four 7/8" bolts holding it on.
/ Tooth Bar #10
Key word is "looks". You can get the EA Wicked that attaches that way if you want but the Standard EA method works just fine and is probably easier to install and I don't think anyone has ever had an issue with it.
/ Tooth Bar #11
Each tooth - in the picture I posted - has a slice on the back side. As you push the tooth bar onto the lip of the bucket - the bottom of each tooth goes under the lip of the bucket. As I tighten down the four bolts - it pulls the TB back and forms an extremely tight fit on the lip. I would bet the tooth bar would have to be beaten off the lip even after the bolts were torched off. This is one of the reasons I chose this TB. Extremely tight, permanent fit.
/ Tooth Bar #12
I have seen the wicked tooth bar and that is the one
I will be getting soon. I have a lot of small brush and
the roots are in the ground and need to be dug up.
willy
/ Tooth Bar
That bar looks very familiar, it's very consistent with what I had years ago. Thanks
/ Tooth Bar
Thanks to all for the input. I checked out some videos of the Wicked Tooth Bar, and it may be a better fit for my application. So going with that one.
/ Tooth Bar #16
Thanks
If you were closer I'd sell you my bolt on tooth bar similar to #2, I regret the purchase.
I suggest weld on teeth or something like a Piranha bar. My issue with the wrap around tooth design is it hangs down about 3 inches below the bucket edge leaving exposed hooks making it a permanent catch all for grass, roots etc. I've used mine twice, then took it off and it's been in the corner of my barn ever since.
Bush Hog 3715 (A64126)
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
39' 9" 3 Bar Drag Tooth Harrow (A66285)
39' 9" 3 Bar Drag...
