What JD tiller is this?
   / What JD tiller is this? #1
SoreButt
Iseki TL2300F
I need times.
   / What JD tiller is this? #2
550
   / What JD tiller is this? #4
it's TINES not times... Go to your local JD dealer with your wallet out.
That's for sure, I bought a set for a 450 tiller in 2002 for $205.
Pro tip, just replace the sharp pointed ones.
   / What JD tiller is this? #5
So my JD 660 rototiller has 36 tines. It was time to replace and John Deere and Westward Parts were both quoting me about $36/tine. So I Googled the part numbers. What I learned from that is that all the tines available were made in Italy which makes me think that JD's and WP's tines were also from Italy.
I ended up buying times from Westlock Tractor Parts in Westlock AB. They quoted me $12.75/tine and when I picked them up the bill was for $11.50/tine. And yes they were made in Italy. :)
So use your head and shop around.
   / What JD tiller is this? #6
The real pro tip is, don't replace them until they break at the curve.
Another pro tip is, curved tines last longer that L tines.
SR
   / What JD tiller is this? #7
SR
I have never had a Deere tine break but I did have a Land Pride tine bend a little.
   / What JD tiller is this? #8
Once they get worn enough in the bend, they will break if you hit a rock/root/ or some other trash.
And with more than 2000 acres tilled, I've hit about everything there is to hit.
SR
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
John Deere 7410 (A53317)
John Deere 7410...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
