300 utility pto problem
/ 300 utility pto problem #1
1ton
International 300 utility
Pto spins but won't turn brushhog?
/ 300 utility pto problem #2
You possibly have broken shear bolt. Pto spins bushhog is not. See if it’s broken the shear bolt. If not could be damaged gear box unlikely but not impossible. Look for the obvious first.
/ 300 utility pto problem #3
Any noise when the pto is engaged? We had a 350 international that did that turned out it took out the splines in the clutch that ran the pto but it made a rattling noise when the pto was engaged had to split the tractor but wasn't too bad of a job.
/ 300 utility pto problem #4
Does the driveshaft going to the brush hog spin? If you manually turn the driveshaft does the brush hog spin?
2019 BOBCAT T595 SKID STEER (A65053)
2019 BOBCAT T595...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
1997 International 3800 School Bus (A64194)
1997 International...
Pig Statue (A64557)
Pig Statue (A64557)
