How to remove these stains
/ How to remove these stains
Ok, will do. I’m going to have to wait about 5-6 hrs for the sun. I have 12.5% bleach, which is twice as much as Std 6-6.5% and 60% stronger than the 8-8.25%. I might just cut to chase and do 50-50% bleach to water after sun subsides. I always wet down the surfaces below and or cover w huge area rug padding…Thanks again and I’ll post back later this evening
/ How to remove these stains #22
50-50 is ok! Like I said if it doesn’t work on a small area without rubbing it’s not mildew. From the looks of it in the pictures, I don’t think it’s mildew!
/ How to remove these stains #23
I just looked at the pictures again, I’m thinking if it’s not mildew, call the roofing company and explain the situation, probably not the first time they have heard that problem!
Good luck!
Good luck!
I have already contacted GAF last Tuesday and this is what they sent me...
  • Algae Staining On Shingled Roof Surfaces Steep Slope Technical Point.pdf
I would love to read that but it won’t open
Can you just post it?
I’m remote now but will try posting later this evening…
Here you go - you’ll have to zoom in
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
2014 DODGE 5500 SERVICE TRUCK (A65643)
2014 DODGE 5500...
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
2009 International 7400 Crane Truck, VIN # 1HTWGAAR39J160604 (A65563)
2009 International...
