How to remove these stains
   / How to remove these stains #11
TSP mixture. It's a hardware store item.
There are other "recipes" for cleaning only. Just search TSP mixture for aluminum siding.
   / How to remove these stains #12
I’m a 40 year retired painting contractor. What I would do is just mix a very small amount of bleach and water ( 4 water 1 bleach) try that on the lowest part of gutter. Just use rubber gloves and a rag, if it’s mildew it will disappear in a few minutes!
If you have any questions p m me!
   / How to remove these stains #13
I would try the 9% vinegar mixed with some water
as vinegar kills mildew/mold and its a great cleaner
willy
   / How to remove these stains #14
I use bleach mix with dish soap works well.
   / How to remove these stains #15
Another product that will work is "RV black streak remover". Works great on aluminum and painted metal.
   / How to remove these stains #16
Thomas, No doubt the bleach works. I used that initially. In my case, the bleach slightly changed the color shade and required me to re-paint. Guess it depends on several factors (color for example). Mine were an off white that matched the facia boards and after wiping the gutters using bleach, I could tell enough difference that it looked odd to my eye. At least for me, I would not use bleach again on a painted surface. So, not against you on this, just a word of caution here.
Ok, I mixed 1/4 12.5% bleach to 3/4 water w 1 tablespoon of liquid soap. I agitated and applied w a paint brush and moved brush back and forth 3-4 times. It barely lightened it. Then came back dish scrub pad, dipped in solution and scrubbed back and forth. Then hosed down w the strongest pressure setting from hose bib.
The first pic is what it looks like now; second pic I have done nothing. To me, the first pic is a slight improvement, but not much.
Any suggestions since i have all the supplies out? Should i strengthen the bleach %? Skip the soap? Anything else?
Thanks
   / How to remove these stains #18
“I’m a 40 year retired painting contractor. What I would do is just mix a very small amount of bleach and water ( 4 water 1 bleach) try that on the lowest part of gutter. Just use rubber gloves and a rag, if it’s mildew it will disappear in a few minutes!”
I would say if the above didn’t work, it’s not mildew!
Maybe call a gutter company and ask for a recommendation! Sorry that’s the best I can offer! ☮️✌🏻
Thank you Alan - First, I corrected my mixtures above...used 25% bleach to 75% water, 1 TBSpoon of liquid soap [before i said bleach but corrected].
Would it be best to apply w sun on it or not? It's almost perfect weather here at 68 degrees and RH of 35%...I can wait later if no sun, but it is pretty windy too...10-15MPH...Thanks again.
   / How to remove these stains #20
I would try a small easy to reach section in the shade first, before doing too much just to see if it works! Keep me posted! If it does work and you spray with a pump up garden sprayer make sure you wet down any plants & things you don’t want to bleach also wear eye protection!
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
John Deere 4510 (A53317)
John Deere 4510...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Zero Turn Mower (A59231)
Zero Turn Mower...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
