CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,442
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
PRogress,
Valve and plumbing in, System works as desired!
I took photos while everything was exposed, but this morning my wife tried to move them.....vaporized
Here are some "make up shots" as things are going back together.
It's nice to have float on the boom, and the freed up aux ports will be a boon for the blade and york rake.
Sure does suck up the time. And I'm not realy happy with the "arches" for that pair of lines. might need to see what can be done to route them low like the other pair.
While the hard lines were out for painting, It looked like a congregation of snakes on the sheet of card board.
I got real lucky with a few of the bends in the 1/2 inch steel line, snaking through what I thought would be near impossible. There is really NO ROOM for much of anything to pass under or between things. Certainly some of the runs would not have fit rubber hose.
Now if I could just figure why the 3PH doesn't fall when the lever is in float and the engine off...... ;-)
