Favorite diesel can?
/ Favorite diesel can? #1
TuckR
Member
Spokane, WA
Kubota L3302
Hi all, looking for a purchase recommendation. I'm looking for a diesel container to fuel my Kubota L3302. It'll hold 14 11 gallons, and I really don't want to buy three two 5gal diesel containers. The glass can I bought were for gas, and they sucked, so hoping to use the collective knowledge here to point me in the right direction. Currently I'm burning through a lot of diesel as I turn a rural 20 acres property into a homesite, but I expect my fuel use will fall precipitously once the property is established, so I'm not terribly interested in big tanks as I just wont be able to use it fast enough.
I've looked at the Scepter Duramax and the John Down 15 Gallon can, but the reviews where mixed enough that I hesitated on pulling the trigger.
What say you?
/ Favorite diesel can? #2
The cost of a 15-100 gallon tank, plus a pump. That is quality enough to last. Compared to 3-5 five gallon cans…it’s a no brainer for me.
Plus as soon as you get beyond 10 gallons the ability to move your tank around by hand quickly gets really hard.
I like VP race cans, can pour it like you mean it and they are tough. I’d like to have a 250-500 gal tank to fill once a year when prices are low but I’d still probably fill my tractors with five gallon cans a lot. I hay and all the places I hay are far from home, not uncommon for me to burn 30 gallons in a day between my two small hay tractors. I’d never mount a tank in my truck, maybe a skid, but five gallon cans are just too cheap and easy for us guys that aren’t using 100s of gallons a day.
/ Favorite diesel can? #3
second the VP racing can, it is what i'm using after getting tired of the other crap with spill resistant crap caps.
/ Favorite diesel can? #4
I don't know which can I have, it came with the tractor, but it flows fuel just a little faster than the tank on my Yanmar YM2310 can receive it because of the filter screen installed in the fuel tank opening. This means I am careful when filling the tank to hold the fuel can such that it is not flowing at the max. I like the VP racing cans but cannot use them because they flow too fast. I could get rid of this problem by removing the filter screen but I think it is necessary in my situation. Even though I am very careful when fueling and always make sure there is no debris hanging around that can fall into the fuel opening I still find pine needles in the filter screen. You may want to consider this if your fuel tank also has a filter screen.
Eric
I got a 30 gallon fuel caddy free from work since it was on the scrap pile for a defective handpump. $40.00 later from Harbor Freight....... a $500.00 something 30 gallon fuel caddy cost me only $40.00
Let me know if you see another one in the pile šŸ˜†
/ Favorite diesel can? #7
If you are going anything bigger than 5 gallon cans, keep in mind the larger the can/tank, the logistics of moving it be come more complex..... IF really large you may have to consider truck mounted tank or onsite delivery....Personally my SCUT only holds about 7 gallons and I never let it get below half a tank so one 5 gallon can is enough, but have considered a second..... Also consider where you fuel filler is, mine is at same level as seat and I can rest can on fender as it fills tank.... Keep in mind #2 diesel weighs about 7.25 pounds to the gallon....
And yes I use one of the hated jugs because can rests on fender and spout drops into filler neck....
/ Favorite diesel can? #9
I have the 3901 don’t worry about your machine using a ton of fuel, the modern common rail diesel is much more fuel efficient than most older machines. I can dig all day with my backhoe running about 2000 rpm and not use 5 gallons. Brush hogging all day is about 8 gallons
/ Favorite diesel can? #10
My favorite? Two plastic jerry cans that left the Army with me; I dropped some money into new seals for them, and some other parts, so I ought to be able to use them for a long time to come.
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2012 DRAGON 130BBL VAC TRAILER (A60736)
2012 DRAGON 130BBL...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
KALMAR 4X2 YARD MULE (INOPERABLE) (A60736)
KALMAR 4X2 YARD...
1995 CATERPILLAR 938F WHEEL LOADER (A62129)
1995 CATERPILLAR...
