Any Excavation Professionals Feel Like Giving Advice?
/ Any Excavation Professionals Feel Like Giving Advice? #81
304 is a mixed stone specification so there is no size to call out
no size ?? every type of aggregate is a mixture of different size and can be described by it … from 2” to 0 or from 3/4 inch to 1/4 inch … etcetera
/ Any Excavation Professionals Feel Like Giving Advice? #82
I've never seen it move unless some digs it up. How does it move with 4" +rock on top??
Probably it moves up in the same way that any size rocks move to the surface. It's called frost-jacking. Happens faster in some climates than others.
/ Any Excavation Professionals Feel Like Giving Advice? #83
Where in "grade 8" for bolts does it give any notion about what's graded? is it 1.6x bigger? better? than grade 5? in what way?
It doesn't need to tell you. It's a specification and you either know it's what you need or you look it up.
How viscous is SAE10W-40?
How big is 304 gravel?
/ Any Excavation Professionals Feel Like Giving Advice? #84
I'm not sure what you are trying to learn from the guy. Aren't most specs based on some quality that needs to exist in the final product? Looking at the 304 spec online today, it's interesting that the size, shape, crush, fines or not, and even the water resistance in the 304 specs varies with what what substrate is used to make the 304 out of. So for that material I get the impression that it is designed to be an intermediate compaction layer material rather than a topping.
For the top dressing layer - even on a parking lot - I'd be a bit more picky about the material and probably go down to the yard and pick it out instead of going by some commercial spec.
I recall one church parking lot that used small river rock - washed and not crushed, so it had no fines. It was beautiful but hard to walk on and never would settle down. I think that a cure for that would be to top dress with some small crusher run w/fines.
Back before covid I was following a couple of apt. house parking lots that put in chopped up recycled asphalt. So far I'm unimpressed and am curious how they plan to stabilize that stuff.
/ Any Excavation Professionals Feel Like Giving Advice? #85
So, whatever 304 is; the way this works, is, you, as a material producer, apply to get your material approved with the state. Your rock mine wants to be FDOT. you jump through the hops, do sampling, testing, they do sampling and testing, at regular intervals, and your material is from an approved pit.
Now, here's the truth, let's take XYZ imaginary pit in Ocala FL. They produce fantastic FDOT approved material, great. You, as a homeowner or contractor probably will Not use that same material. The added cost if FDOT approval, means that pile of rock costs more.
Now, there is probably 3 or 4 piles;
1 is FDOT approved, costs the most; has a pit proctor, and is excellent material for its intended purpose
2 is for major commercial/County contract work. it's pretty much the same as pile 1, but hadn't been through the same testing, and is slightly cheaper; contractors testing company will sample onsite to get LBR, proctor, % passing the 200 sieve, ect
3 is fairly ok; its not bad material, but it has more fat clays, chirt/flint, maybe a softer rock, it works, but would not meet requirements of 1 or 2, and this is probably what the Vast majority of contractors that care about doing an OK job buy; the GC or owners rep doesn't have a spec for the rock but 10" limerock base, or 304 whatever, or ABC, who cares; this will fit the bill,
4 is sold to home owners and shady contactors; its probably 60% overburden, trash, mixed with the trash material. You as a guy that doesn't know better, This is what your buying... Nearly anything or anyone who isn't going to pay to test the material is using this. This sounds bad; but is exactly what they guy who wants a 1200ft stabalized road on a dairy farm needs, or a logging access, ect.
Sorry to be the bearer of bad news, but thus talk about spec only matters if that material is held to the spec.
/ Any Excavation Professionals Feel Like Giving Advice? #86
ho yes just google it, super clear, its standardized across the industry...
/ Any Excavation Professionals Feel Like Giving Advice? #87
I attached screen shots showing the approved FDOT optional base groups, and sub standard base groups. Notice there isn't #57, #8, #83, ect.
And maybe back to the OPs question; the reason it's called OBG, Optional Base Group, is typically, plans will call for say, OBG 9, and it's the Contractors choice of which material to use, as long as it meets FDOT Spec and thickness is defined by the chart above. So contractor A might use 10" of Limerock LBR100 and contractor B will use 6" Asphalt B-12.5; but the materials are considered Equal, and the state would pay the same for either.
Keep in mind, the way this generally works; the requirements are basically specced out, but you would Never dictate Means/Methods.
/ Any Excavation Professionals Feel Like Giving Advice? #88
Thats not the case around here. I can buy the same limestone that the state or county uses. They dont have separate piles. There is no "homeowner or shady contractor" pile.
/ Any Excavation Professionals Feel Like Giving Advice? #89
yeah seem weird like statement but out here we have some quarries that even if they are crush to speck it wont pass ministry standard and can't be used for certain application like cement mixing or asphalt mixing because of their rock type... I believe its the silt content but not sure, so it will be sold for cheaper.
edit: I should precise that we have a very think over burden and the outcrop are rare so we take what we get
/ Any Excavation Professionals Feel Like Giving Advice? #90
Every crushed gravel has a stone specification with size to call out. Every one.
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2019 John Deere R-4038 (A61307)
2019 John Deere...
2018 Kubota L2501 (A60462)
2018 Kubota L2501...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2022 John Deere 5055E (A60462)
2022 John Deere...
