Looking for small off-road trailer
/ Looking for small off-road trailer #21
Made my own all-around the yard dump trailer in the early 90's and used a salvage yard rear axle from a tiny Honda car.
145R-10 Tires
/ Looking for small off-road trailer #23
comparing these two, apparently the WM unit has heavier metal (16ga vs the DR's 20ga), and the WM has a 50° dump angle vs the DR 35°, so stuff should actually fall out of it better.
I'm intrigued, particularly if one could reasonably attach height extenders to fit a bit more chips.
Wouldn't want to go too high though, may roll the whole unit...
/ Looking for small off-road trailer #24
Made in Idaho, I have seen a couple of these and they are well built.
/ Looking for small off-road trailer #25
View attachment 791320View attachment 791321
A major shortcoming of the DR VersaTrailer (in addition to the limited 35˚ dump angle) is that while it can carry up to 2000#, it can only dump 600#. I considered getting one years ago, but that dump limitation was something I just could not live with.
I checked with Woodland Mills. Their Multilander trailer can dump its full 2000# cargo rating.
/ Looking for small off-road trailer #26
Not to defend the DR but I wonder if the dump limitation is a weakness of the winch or can the frame not take the changed geometry's stresses? If the latter, that's definitely a bad thing and says a lot about the rest of the trailer!
/ Looking for small off-road trailer #27
It's a design limitation (probably of the boom). One of their options is a 1500# rated hoist to replace the hand crank winch. Even with that electric hoist, the 600# dump limitation remains.
/ Looking for small off-road trailer #28
My older Woodland Mills trailer is similar in appearance to the DR but differs in details. It can dump a bed full of chips without much problem. I have the winch in the high speed position and I'm built more like a marathon runner than a linebacker.
/ Looking for small off-road trailer #29
Do you have the Woodland Mills T-Rex trailer?
/ Looking for small off-road trailer #31
I bought a CMI dump trailer, 4000 lb gross. Front, back and sides come off, only the four corner posts are left. Trailer weighs 700 lb.
I'm using hydraulics off of my tractor to dump it, but you can dump it from a UTV with electro-hydraulic.
They also have smaller sizes. I like this trailer a lot. I haul dirt, limbs, wood and use it as a large wheelbarrow.
It is not street legal, speed is limited to 15 mph.
/ Looking for small off-road trailer #32
I built one and had fun doing it. I started with the smallest Harbor Freight trailer in a box. In order to use wheels with the offset and width for real off road tires I ended up using 2" wheel spacers. I miscalculated as 1" would have worked fine. The side rails were some scrap that I had laying around. This trailer has been pulled in excess of thirty mph offroad. It has real wheel bearings vs the tiny little wheelbarrow bearings used in many of the commercial produced trailers. I have around $600 invested in it.
I looked into this exact idea. I need to learn to weld, it holds back a lot of good ideas I have. Got a neighbor who is half way decent and I think would teach me, got to get on him this summer about it.
Good job!
/ Looking for small off-road trailer #34
These are two of the three trailer I use on my property... I would need to change the tires on the double axel quad trailer they don't have enough flotation in the mud but the tandem oscillating axel dose wonder, you can go across a ditch and the trailer bed pretty much stay level. (see video below for demonstration)
The second one is a very solid trailer but too heavy for off roading behind my quad but I use it a lot in the field and on solid ground... a very good trailer to pull behind the tractor tho...
that tandem video is worth watching if anyone is on the fence! Wow.
/ Looking for small off-road trailer #37
It looks very good, however wheels sticking out like that would be a big problem in my case due to many trees on the property.
I needed trailer not any wider than ATV or whatever is pulling it behind.
Your mileage may differ - perhaps your property is more open or trees further apart and it's not a big deal?
/ Looking for small off-road trailer #38
It really isn't a big deal. Plenty of two tracks and open fields on my place. About the only time that this rig has to get out into the brush is when I retrieve a downed deer. I can pick my way through most of it or just drag the deer out to an access point if needed. That wide stance makes a super stable trailer.
/ Looking for small off-road trailer #39
I needed a trailer that could transport my ATV an also go anywhere thru the woods that the ATV could go.
I'll post some photos later, but I received my Polar hd1500 this past week and put it to use this weekend.
1) Great instructions, it's simple to put together but I have been SO disappointed with instructions from places, I was impressed.
2) Solid bolts and hardware, again impressed.
3)Works great! I can lay down in it like a bath tub and its deeper than my truck bed, I'd say two full carts equals a full bed of sticks or dirt, and for dirt and heavier products....well my Tundra has a low payload so I can probably haul more in this trailer.
I used it mainly for firewood collection and towed with my ATV. Great getting into areas my truck or tractor struggle with to collect branches and what not. The big downside is its dumping action, the dump is smooth and easy to rotate which is great, but things don't just slide out. It takes a person actually raking/pulling everything out. This is a known issue if you look into it though and IMO not a deal killer.
If you can make your own and weld, sure do that you can probably do better. But for a guy like me who can't weld...I'm very happy with this trailer, it does exactly what I want and is very well built IMO.
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
New/Unused Wolverine 3 Point Hitch Coupler (A65583)
New/Unused...
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
