coobie
Super Member
- Joined
- Sep 19, 2004
- Messages
- 6,402
- Location
- S.Michigan
- Tractor
- Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
What is better in board boat motor setup merc-crusier or Volvo penta?Thanks for any info..
2012 charaprall 19 ft fish/ski boat with 4.3 mer-cruiser engineEverything now is outboards. What sort of boat are we talking about?
220 hp pushes it to ~50mph. Running hard skiing all day will burn 20-30 gallons.2012 charaprall 19 ft fish/ski boat with 4.3 mer-cruiser engine
No ski tower.220 hp pushes it to ~50mph. Running hard skiing all day will burn 20-30 gallons.
Mercruiser is (IMO) easier to source parts and less expensive. Merc mechanics, in my area, are easier to find. Upgrades; 4 bbl carb, better prop (prefer torqueshift) and speed tabs. Unless you want a little more, bolt on intake and….
Does it have the ski tower too?
The only thing I really disliked is putting a 280 in reverse there is no lock on the outdrive so it can lift up the entire outdrive if over throttled...
Your 280 drive does have a reverse lock. Check it out real close and the end of push rod linkage is not able to move up and down.
23 years ago when I was shopping, the Merc was way more common and sold for much less than the Volvo-Penta equipped boat. Also back then the Merc was considered more reliable and easier to have serviced.What is better in board boat motor setup merc-crusier or Volvo penta?Thanks for any info..
No ski tower.
Looked at the design and some service videos. Another Volvo 280 would have been just fine for me but the engine and boats condition are also a big consideration. I was never crazy about the screw drive trim / lift on the Volvo though.Volvo used clutch cones, as does the Bravo Merc. The Alpha I and II are STILL a dog clutch, that relies on an ignition cut off to work. This is a very primitive way to engage and disengage gears. Volvos are better in every way. More expensive, but better. Merc isn't a USA company any more, by the way.. Sea Ray was a good brand of boats. They are designed and built well.
