LS Tractor - Drives Slowly - Bad Hydrostat?
   / LS Tractor - Drives Slowly - Bad Hydrostat? #1
goddom
Flat Rock, MI
LS G3038H
Hello,
So I have 2013 G3038H tractor with about 1050hrs on it, and the tractor moves so slowly now - in all gears (high, medium and low). Fluid is not very old, and still looks clean. I changed the filter recently and cut it open to see if there was any metal debris in it - but it was clean.
The dealer has kind of given me mixed information on what might be going on. One guy said the hydrostat was toast. Another suggested that a hydraulic distibution block for the loader and hydrostat could have a pressure leak.
I think you guys will be much more helpful than they are! LOL
   / LS Tractor - Drives Slowly - Bad Hydrostat? #2
Is it slow in reverse?
   / LS Tractor - Drives Slowly - Bad Hydrostat? #4
Just spitballing, did you check the linkage from the pedals?
I have. It seems like its a pretty solid rod to a lever on a rod that goes into the hydrostat casing. I had speculated that maybe the rod loosened up internally and isn't moving the squash plate properly.
   / LS Tractor - Drives Slowly - Bad Hydrostat? #6
Well, that's not good if thats the case. No adjustment points externally? I'm not familiar with LS.
None that I can see. I will try and take some pictures tomorrow and post them.
   / LS Tractor - Drives Slowly - Bad Hydrostat? #8
Yeah, you're going to get more help with pics.
   / LS Tractor - Drives Slowly - Bad Hydrostat? #9
I’m not familiar with your model but many of the smaller LS tractors had a roll pin wear problem on the hydro pedal/lever actuation rod. Pedal moved, rod moved, just not as much as it should.
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2025 FREIGHTLINER M2 NON CDL BOX TRUCK (A51222)
2025 FREIGHTLINER...
1997 John Deere 8100 MFWD Tractor (A52128)
1997 John Deere...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
