Trailer painting
/ Trailer painting #42
For something like that with surface rust I use a bucket of soapy water and a scrub brush, then when that dries I brush on Rust-Oleum professional oil base rusty metal primer. You can buy it at home Depot for pretty cheap by the gallon and it goes on pretty thick. I give it several days to dry, then paint over it with one of the Rust-Oleum professional oil base paints and give it a few more days to dry. I've done a lot of implements and a tractor with this procedure and it holds up really well for years and I don't have to go through all the work of completely removing all the rust as the rusty metal primer neutralizes it. I've also shot this with an HVLP gun thinned with acetone -works great. I believe it's an alkyd enamel just like tractor paint.
The trick is making sure you wait the several days for each stage to harden up
/ Trailer painting #43
I like the color of the wood stain. Looks really nice.
/ Trailer painting #44
Learn the magic of OSPHO liquid. You still need to protect your eyes & skin. Will leave the metal ready to wipe the dust/powder away, then paint to your heart's content. Any auto paint store should have it as well as Lowes or Home Depot
/ Trailer painting
Great work. Would you tell us the cost of the wood for the new deck?
My 18' needs one.
$332 with tax got me 11 2x8x16' boards and 11 2x8x8 boards.
The 2x8 boards got cut down to 3' for the dove, and the remaining 5' is up front. Which is how the original deck was.
The original deck wasn't too bad at only 8 years old.....
But going to this much trouble and wanting it nice....$332 is like 5% of what I have in the trailer as it sits now
/ Trailer painting #47
I painted a 88 toyota truck, which is know for rusting, with PPG epoxy primer and paint in 2012. I did not like the way it's held up. The truck is needing another paint job this spring. I will be going with the old tried and true, High build primer with top coat of paint.
I don't know anymore. Everything you read on epoxy primer sounds fantastic. Maybe those people just live outside the states that use salt. Anyways, outside of a galvanize dip...I don't know what to use.
/ Trailer painting #48
It's complete and ready for the road
Since you did it recently and I have never done it, how do the boards screw down to the metal frame? I have some that are damaged. Do you just use self tapping metal screws? Pre-drill? I saw the holes in the “joists” in your original pictures. Set the boards and drill up from below?
thanks for your advice!
/ Trailer painting #49
I used these when I did my trailer, have to predrill & they cut there own threads.
/ Trailer painting #50
And Ace..
/ Trailer painting
There are a various assortment of trailer decking screws ranging from #12, 1/4" and 5/16. Some self drilling....some just self threading that require only a pilot hole. T-30, T-40, or #3 phillips head.
Some are ACQ rated, some just plain oiled black.
Dont know that one is any better than the next. Because I have NEVER been able to successfully remove any type of screw after enough time has passed that the deck needs redone. They usually all just snap.
/ Trailer painting #52
Were those SYP? PT?
Thanks
/ Trailer painting
Were those SYP? PT?
Thanks
Yes. Local amish lumber store that probably sells and moves more building material than the lowes or menards in my area.
They supply ALOT of polebarn contractors and house builders in the area.
Their prices are usually a tad bit better than menards 11% rebated prices.
The 2x8x16 boards were $18.95ea and the 2x8x8 were $9.25ea
Does your trailer have a dovetail? If it does and you can keep lumber under 16' it keeps cost down. But even if not, I'd consider 18' lumber.
I would have loved to NOT have the seam at the 5' mark. Really wish the trailer was a 20+4 instead of a 21+3. Because It seems they dont make 22' lumber......and 20' is too short. But I "could" have gotten 24' lumber and not had a seam. But 2x8x24' boards were about $100ea. And I wasnt gonna spend $1100 to deck the trailer. I'll deal with the seam
/ Trailer painting #54
I'm gonna add about my trailer. I was in high school rising around with my friend in a 65 Chevy truck. Windows down, heard a loud boom. Turns out a welder was nearby and a tank blew up. It blew his stomach open. He died on way to hospital.
Years later I thought I saw a corner of a trailer sticking out of a bunch of overgrown. Finally caught someone there and bought it. It was built by that welder. Was at his shop, complete except for paint and a floor. They took it home and used it to move hay. Never had a floor on it. I never put a floor on it either. It's a flat bed over the wheels. I've hauled 32' pipe, trusses, bundles of lumber, has a deck I bought sitting on it as I type. Been kinda handy without a floor. I came across a 12' x 24' deck with roof and hand rails, all treated, for 135 dollars. Got the cinder blocks too. Try buying all that at the store. Plus, it is already built nicely. Plan on making a nice back porch with it. I looked like a parade float going down the road. Took a picture and sent it to momma, saying I was headed to the Mardi gras parade in Shreveport. But, I've never been.
UNUSED GIYI 29" MINI HYD SIDE SHIFT PALLET FORKS (A62130)
UNUSED GIYI 29"...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63118)
2019 Cadillac XTS...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
2011 JOHN DEERE 544K WHEEL LOADER (A62129)
2011 JOHN DEERE...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
2024 SILVERBACK 53XH3A 53FT TRI/A GOOSENECK CAR HAULER TRAILER (A59910)
2024 SILVERBACK...
