Woodland Mills WC68 vs WC88?
   / Woodland Mills WC68 vs WC88?
OTOH the Woodland Mills has some features that I wish the Woodmaxx had, like the clamshell rotor housing that seems like it would make knife replacement easier.
The clamshell is the biggest feature that I prefer. It's a huge benefit to be able to easily clear a jam, and makes blade maintenance super easy. I fought with some of those flat head bolts that has the heads filled with crud and stripped on an older chipper, and it was through a little access door. The ability to actually get to both sides of the bolt and put some leverage or heat on it is a big win in my book.
Also, good info on the valve. Where did you buy your replacement?
   / Woodland Mills WC68 vs WC88? #23
I have a woodmaxx wm8m on a 45hp (engine) tractor. Do not get anything smaller than an 8" in feed opening for the simple reason of less trimming. Anything over 4-5" is firewood to me, but that 8" opening disappears real quick when it's not a matchstick. If I ever stumble across a used mx9900 with the 9x9 opening I'll definitely grab it. I just can't justify the new price tag when I found my wm8m for $1400 used.
I have a woodmaxx wm8m on a 45hp (engine) tractor. Do not get anything smaller than an 8" in feed opening for the simple reason of less trimming. Anything over 4-5" is firewood to me, but that 8" opening disappears real quick when it's not a matchstick. If I ever stumble across a used mx9900 with the 9x9 opening I'll definitely grab it. I just can't justify the new price tag when I found my wm8m for $1400 used. View attachment 788480
Thats a pretty good deal I would say. For that money I wouldnt really care if it was a 6" vs 8" vs 9" opening....
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2005 Toyota Highlander SUV (A55853)
2005 Toyota...
