Woodland Mills WC68 vs WC88?
   / Woodland Mills WC68 vs WC88?
OTOH the Woodland Mills has some features that I wish the Woodmaxx had, like the clamshell rotor housing that seems like it would make knife replacement easier.
The clamshell is the biggest feature that I prefer. It's a huge benefit to be able to easily clear a jam, and makes blade maintenance super easy. I fought with some of those flat head bolts that has the heads filled with crud and stripped on an older chipper, and it was through a little access door. The ability to actually get to both sides of the bolt and put some leverage or heat on it is a big win in my book.
Also, good info on the valve. Where did you buy your replacement?
   / Woodland Mills WC68 vs WC88? #23
I have a woodmaxx wm8m on a 45hp (engine) tractor. Do not get anything smaller than an 8" in feed opening for the simple reason of less trimming. Anything over 4-5" is firewood to me, but that 8" opening disappears real quick when it's not a matchstick. If I ever stumble across a used mx9900 with the 9x9 opening I'll definitely grab it. I just can't justify the new price tag when I found my wm8m for $1400 used.
I have a woodmaxx wm8m on a 45hp (engine) tractor. Do not get anything smaller than an 8" in feed opening for the simple reason of less trimming. Anything over 4-5" is firewood to me, but that 8" opening disappears real quick when it's not a matchstick. If I ever stumble across a used mx9900 with the 9x9 opening I'll definitely grab it. I just can't justify the new price tag when I found my wm8m for $1400 used. View attachment 788480
Thats a pretty good deal I would say. For that money I wouldnt really care if it was a 6" vs 8" vs 9" opening....
Kubota B21 (A53317)
Kubota B21 (A53317)
John Deere 853 20ft Corn Head (A55315)
John Deere 853...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2020 JOHN DEERE 317G SKID STEER (A52707)
2020 JOHN DEERE...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
6 HITACHI WEDGEDOCK COUPLER (A57192)
6 HITACHI...
