Tie Rod Ends KD45 SE HYD Cab
/ Tie Rod Ends KD45 SE HYD Cab
Thank you. My bushings are gone.
/ Tie Rod Ends KD45 SE HYD Cab #12
I took my tie rods out because they were loose. There was no grease at all inside of those parts. I added a grease fitting to them. I also pressed them down in a press to tighten up the joints. So far so good.
/ Tie Rod Ends KD45 SE HYD Cab #13
Is it that unusual of size? I mean, Tie Rod ends in automotive applications are fairly universal these days.
Sorry for the rant but I want people to appreciate how lucky they are to have a Kioti
Moog or TRW are the big US players. India and other places make them too. Most OEM stuff is COTS (commercial off the shelf) figuring out whose shelf is the problem. Quite often the part will be stamped and a little googlefoo will lead you to a new one. Then there's the times where you have to get a set of calipers and figure out what you have, then start catalog digging.
Looks like the DK 45 series L/H is part Kioti T4625-31191 Tie Rod End (LH) for Kioti DK65, DK40, DK45, DK55, DK35
The R/H side is part #T4620-31051 which isnt as easy to find. That one will take some digging.
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2011 MACK CHU (PINNACLE) (A60736)
2011 MACK CHU...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
